Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-17-2010, 11:17 PM
FlightMed14 FlightMed14 is offline
Police chip vs. aftermarket performance chip??
I have a 98 Crwn. Vic. intercepter, If I install an after market performance chip instead of keeping the standard police chip: will it cause any problemes?
I have also up-graded to the "e-3" spark plugs, when I had to replace the plastic intake,"what the He$#", I put Magna-flow mufflers with the true duals that came stock and a K&N air filter. It makes Mustangs mad now: to see a 4 door "sedan" out run or put up a good competition with their "Stangs,"
Old 10-18-2010, 10:47 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Police chip vs. aftermarket performance chip??
No such thing as a police or "cop chip." The only difference between CVPI and standard civilian models are a higher rear end gear ratio, the aluminum or MMC police driveshaft, a smaller torque converter beginning in model year 2000, and a slightly higher computer limited top speed (although mechanically lower top speed than base civilian models).
Where were you thinking of getting an aftermarket tune from? If you're thinking of a "tune-in-a-can," save your money. They are hardly better than stock if not worse. Getting a custom tune for your car from a reputable tuner will net you performance gains over the factory tune. The biggest enhancements are in the shift schedule which will keep you in your power band around town much better. The tune will also increase spark timing based on the octane profile you choose to increase torque and HP, and increase the rev limiter and speed limiter.
You'll need to know the computer code you have installed (a 4 letter/number sticker somewhere on the driver side door area), the rear gears you have (crawl under the rear differential and check the tag, it will probably be a 3 55 but may be a 3 27 in a 1998 CVPI; if there's an L where the space should be, it has a Trac-Loc), and any modifications you've done, if any.
I got my tune custom made by Lonnie at Blue Oval Chips. He's the best with these cars. Alternatively, you can go to a local tuning shop and get a dyno tune. It will cost more but can get you a few more horses out of it.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Help Finding the right performance... _Monty_ Silverado 0 02-22-2010 02:09 PM
aftermarket crx shocks vs aftermarket integra shocks UncleBenRep Wheels/Tires/Suspension 1 06-29-2007 07:25 AM
mopar performence vs aftermarket PlayStation3 SRT4 8 10-20-2006 03:53 PM
Performance Chips vs Honey, where's the key? n8zdogg Durango 1 07-17-2006 04:20 PM
Does 97 GTI VR6 come with techtronics chip or aftermarket? Car2ner GTI 1 08-02-2004 10:55 AM
