Go Back   Automotive Forums Car Chat > Dodge > SRT4
Old 10-08-2006, 08:11 PM
PlayStation3 PlayStation3 is offline
mopar performence vs aftermarket
hi, i say i an 04 srt with 12k miles on it for 18k today and i was wondering would it be better if i went with mopar perfermence upgrades or use aftermarket upgrades. and how is realibity with more upgrades done to it. and also it will be a daily driver that i might go to the speed way with when i do some "enhancing" to it.
Old 10-09-2006, 04:31 PM
Turbodog97's Avatar
Turbodog97 Turbodog97 is offline
Just a Neon
Re: mopar performence vs aftermarket
Honestly, I would suggest using aftermarket parts rather than Mopar.
05 Srt4
Agp 3147 w/supporting mods
97 Mx-5
T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box,
Old 10-09-2006, 10:31 PM
TEXSRT4 TEXSRT4 is offline
i have to disagree. the mopar parts are the way to go, UNLESS you know what your doing!!!!! mopar parts are easy, really easy, to install. there is no messing with anything. just plug it in and go. this is coming from someone with LOTS of aftermarket parts on his car. the only mopar part i have is the short shifter. everything else is aftermarket, and im still telling you to go mopar unless you know how to tune/modify.
Old 10-10-2006, 11:58 AM
Turbodog97's Avatar
Just a Neon
Yeah, that is a valid point, if you are pretty clueless with cars and only know simple mechanics then Mopar upgrades would be benificial. But if you are a money saver, like me, then getting your parts from 30 different sources would be more cost effective than one Mopar kit(or accessory).
05 Srt4
97 Mx-5
Old 10-10-2006, 12:37 PM
neon_rt's Avatar
neon_rt neon_rt is offline
One thing about the Mopar Kits is that the dealer can still work on your car. All of the on board diagnostics work as designed and nothing is bypassed or tweaked (giving false signals to the ECU). You can get 300hp in Mopar Performance kits, have it installed by a dealer and have everything still fully functional, including the factory warranty.
It is cheaper to buy seperate parts one by one (maybe). But after you add a piggyback controller, fuel regulator, aftermarket injectors and have it dyno tuned, there is a lot to go wrong that the Dodge dealer is not going to have a clue about.
Old 10-10-2006, 02:01 PM
Turbodog97's Avatar
Just a Neon
Only one thing about that though....Not all dealerships warrenty(or will work on) with Mopar parts. Just because XXXX dealership installed the s2 kit and for some reason your third gear goes out...well, in most situations they will try to corrilate the two. etc. etc.
05 Srt4
97 Mx-5
Old 10-19-2006, 07:06 PM
fibersrt-4 fibersrt-4 is offline
the dealer is more prone to working on a car with mopar parts as aposed to aftermarket! and the stg 3 kit is pulling some great times at the drag strip!
www.TeamHazumi.com
Srt's are so amazing they had to make it in the neon body to bring to coolness down otherwise peoples heads would blow up!
Old 10-19-2006, 10:40 PM
Turbodog97's Avatar
Just a Neon
No necissarily...but I could see how they would be less likely, but in most scenarios, they don't give a rats ass either way. Just today I tried to get the tps wire fix and they wouldn't touch my car, blaming it on s1 and the mopar bov...go figure
05 Srt4
97 Mx-5
Old 10-20-2006, 03:53 PM
dealerships are gay!
www.TeamHazumi.com
