Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 10-15-2010, 07:35 PM
Bowhuntz2010 Bowhuntz2010 is offline
Shifter/linkage issues?
My shifter in my 03 carlo is very difficult to shift between all gears. There is alot of resistance moving it and makes a loud click when it does move into another position. what seems to be the problem?
Old 10-15-2010, 08:07 PM
danielsatur danielsatur is offline
Re: Shifter/linkage issues?
The linkage could be bent!
Old 10-16-2010, 10:34 AM
Blue Bowtie's Avatar
Registered Offender
If you remove the cable from the lever at the top of the trans, then remove the cable anchor bracket from the trans, you can straighten out the shift cable and see if the situation improves.
If it is no easier to move with the cable disconnected, the problem is likely in the cable or floor shifter.
If it becomes easier to move with the cable disconnected, the problem may be in the trans or in the cable itself once it is bent into position. You can clean and lightly lubricate the cable at the trans end and try to work the lubricant into the cable housing. If the cable is damaged, lubrication may not help.
If the problem is in the floor shifter, disassembly, cleaning, and inspection should reveal any worn or damaged parts. Cleaning, lubrication, and adjustment may solve most of the problems.
93 shifter linkage meowzamixen Grand AM 2 06-07-2007 01:35 PM
Shifter Linkage? 1988 SoCalDude Almera | Sunny | Pulsar | Bluebird | Tiida | Versa | NX | Avenir | Tino | Stanza 1 03-24-2006 01:04 PM
Shifter Linkage excidere Taurus | Taurus Wagon 1 03-15-2005 06:51 AM
Cable Shifter Linkage GrungeAholicVR4 3000GT/Stealth 1 03-09-2004 09:17 AM
GSR short shifter linkage... Pineapple Devil Integra 1 02-04-2002 03:53 PM
