Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 10-15-2010, 08:36 AM
samthecarman samthecarman is offline
2007 Corolla engine compartment vibration/knocking
Hi all, I am having some trouble diagnosing a particular problem with my Corolla
There is a constant knocking noise that starts out soft and gradually gets louder coming from the left side of the engine compartment. It only happens when sitting still with the car in drive. As soon as I put the car in neutral or reverse the sound goes away. It usually happens when it is cool out/car is just started up, but it is has occurred in warmer conditions. I did a quick check of the engine compartment to check for loose/broken engine mounts, components, etc... but found nothing. Thanks in advance.
Old 10-27-2010, 01:07 AM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Re: 2007 Corolla engine compartment vibration/knocking
Check your Air box, that tends to vibrate.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 12-31-2010, 09:28 PM
You were right it was the air box. Added 1 washer to the mounting bolts and the noise went away.
Engine Conversion Jezzaa Corolla/Matrix/Voltz 0 12-18-2009 10:27 PM
Vibration/buzz from engine compartment dcleckler Tracker 4 01-24-2006 07:57 PM
Corolla Engine Vibrates and Sputters at Idle dwilliams141 Corolla/Matrix/Voltz 2 03-28-2005 09:41 PM
2002 Corolla / Engine Vibrations Origen Corolla/Matrix/Voltz 1 01-11-2005 07:53 AM
