Old 10-14-2010, 09:55 PM
shankstas shankstas is offline
Lock of the Trunk activates sometimes
Hey all, I have a really frustrating issue with my 2003 Chevy Trailblazer, basically the trunk closes fine but what happens is that sometimes when I activate my alarm all the doors in the car lock but the trunk doesn't lock. So I have keep pressing the unlock/lock button a couple of times until I hear the trunk finally lock.
I thought it was the alarm failing me so I went ahead and had it switched. The people that switched the alarm said that there was nothing wrong with the main wire that runs through the entire car to lock up the trunk. They also mentioned that I had to make sure that I slam the trunk door closed so that the alarm is able to lock the trunk. Unfortunately the problem still persists, I went to my mechanic and explained everything to him and he said that he was going to move the hinge where the trunk door latches onto a bit more forward so that the trunk would have a higher chance of locking when I press the lock button on my alarm. He also told me he tried it numerous times and it worked every time.
So once I got home and I tried it myself on my second try it fails. :(
This is what I do to check the trunk. I just hit the lock button and I check to see if its open and I repeat the process until it happens. Ive tried this to other cars and they work every time except for my car.
Has this ever happened to anyone else before? I'm just wondering what else could be done because I just want to trust my car when I run out of the car and activate my alarm without the need to check it.
Is there any way to check any of these issues like maybe the lock housing is messed up ? or do I need a new hinge where the lock makes contact to? or should i personally push that hinge more forward than what my mechanic initially did?
The other day it started raining really hard as I got close to my job and when I hit the lock button the trunk didn't lock so I was out there getting soaked in the rain while correcting the issue. This is getting so annoying I really hope someone out here can help me :(
Old 10-15-2010, 09:13 AM
maxwedge maxwedge is offline
A990 racer
Re: Lock of the Trunk activates sometimes
There is no quick answer here, the lock mechanism should be gotten into and inspected for any binding, that is step one.
Old 10-15-2010, 02:49 PM
Thanks for the response :D
Was my mechanic suppose to check for those bindings though? Because it was yesterday when he checked the trunk (he didn't charge me for it though). All he did was move the hinge that is attached on my car closer to the back (so the hinge has a better chance of getting latched by the trunk when its closed) Is there a person better than a mechanic that should be checking this issue? Could I do this myself? Wish I knew more about cars :(
Old 10-15-2010, 07:01 PM
Jethro Jethro is offline
Send a message via AIM to Jethro
My Trailblazer don't have a trunk.
2002 LT Trailblazer 4x4 One of the first of this kind on the road
2003 3500 LT Silverado 4x4 ext cab
2006 Heritage Softail HD FLSTI
Old 10-15-2010, 07:10 PM
So what is it called then ? The back door?
Old 10-15-2010, 07:36 PM
A990 racer
Come on guys, tailgate. The interior trim panel should be removed and the lock/linkage checked for binding, where you are there are no rust isues like here in upstate NY, but this is the first thing to check. A body shop may be a better bet here.
Old 10-15-2010, 09:12 PM
My tailgate has a window that never locks but if i open it when the tb is locked the horn will sound till i get a key in the ignition
trunk issues joecartwheel Regal 4 01-23-2010 11:06 AM
Locked the keys in the trunk! lol Kraya C-Class 1 07-13-2007 08:45 PM
03 Ram QC: Auto door locks Beep when activated Solly's 03 Dodge Ram Pickup | Ram SRT10 2 12-19-2006 06:34 PM
Trunk Doesnt Pop Up When I Pull The Trunk Lever? toicy4ya Off-Topic 7 07-15-2005 12:58 PM
trunk release (on door) won't fully unlatch the trunk - anybody heard of this? tim-may General 7 01-26-2002 11:52 PM
