Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 01-25-2002, 06:40 PM
tim-may's Avatar
tim-may tim-may is offline
Send a message via AIM to tim-may
trunk release (on door) won't fully unlatch the trunk - anybody heard of this?
n/m
Old 01-25-2002, 07:02 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
what do you mean "fully not unlatch"? you mean you push the trunk switch, and the trunk won't open?
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 01-25-2002, 07:49 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
You mean you unlock it with the keyhole in the back and you can't pull it open afterwards?
Troy P.
My "pretty-much-stock" G20
:apoke:
Old 01-25-2002, 08:08 PM
tim-may's Avatar
Whenever I press the trunk button on the driver door, I can hear the trunk "click" as if it has unlocked, but it doesn't. After I press the release button the trunk will only halfway unlock. It will be loose, not totally latched (will move), but not totally unlocked (still won't open) I have to end up using the key. Its' sorta like when you pop your hood -- it's loose, but won't open.
tim-may "newbie who knows nothing yet"
Old 01-25-2002, 08:50 PM
You have the g20t, so you prolly got that heavy ass spoiler on it. Well, after a while, those lift supports that help open the trunk go bad. so maybe thats it. soy ou push the trunk button, but the lift supports aren't strong enough to lift the incredibaly heavy trunk enough so that the latch can fully "unlock".
35% Platinum tint
Old 01-25-2002, 09:47 PM
p_r_i_m_e_r_a's Avatar
p_r_i_m_e_r_a p_r_i_m_e_r_a is offline
Send a message via AIM to p_r_i_m_e_r_a
This is very true,
I encountered the same problem, your trunk clicking is a good sign.
A small spring will remedy the problem(AutoLock door springs)
But there might be a better solution..?
________D________
  • 94 P10 w/mods
  • 92 P10 stock
Old 01-26-2002, 06:45 PM
tim-may's Avatar
I don't have a spoiler yet, but it's quite possible the lift supports are bad .. thanks for the info :sun:
tim-may
Old 01-26-2002, 10:52 PM
paradyme paradyme is offline
It could also be the lifts on each side of the trunk. When their worn your trunk hood does not spring up like it should and that puts added pressure on the selenoid latch. It could be both. I replaced the lifts.
:flash:
paradyme
95'G20t/AUTO/BLK
STILLEN HEADER/INTAKE/JWT/ECU/S3 CAMS/P11 99 G20 RIMS/
VIPER SECURITY/w/ REMOTE START/ ALPINE AUDIO
