Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > 1969 - 1994 Full size
Old 10-14-2010, 02:47 PM
Ranger75th Ranger75th is offline
87 jimmy 5.7 stalls restarts after sitting
Obviously new to the forums so your help is appreciated. I tried the search function with no luck so I am posting my issue here.
I have an 87 GMC jimmy with a TBI fueled 5.7. recently it started stalling at idle whether in gear or not and wont restart till it sits for about a day. After restart I get about five minutes of idle before process repeats. When it starts to stumble if I press on the gas it stays running, but as soon as I let off it dies and wont restart till I let it sit overnight or use starting fluid. I am hoping its just a fuel filter or something easy, but figuredI would get yalls thoughts first.
Thanks for your help.
Old 10-14-2010, 10:11 PM
viggy58 viggy58 is offline
Re: 87 jimmy 5.7 stalls restarts after sitting
well that def sounds like a good place to start. check your fuel pressure too. i dunno the specs but someone on here should be able to chime in eith them.
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Old 10-15-2010, 11:04 AM
Ya picked up a Fuel filter this morning, once it warms up abit I am gonna go put it on. What I am hoping is that its not debris in the tank clogging the pickup. Of course its got a full 40 gallons in it now so I realy don't want to pull it if I don't have to. Lol.
Old 10-15-2010, 03:14 PM
Update:
1.Replaced fuel filter, old one was clogged. Truck will now idle until I shut it off, but will not restart unless it sits or I use starting fluid. (before it would idle for about 5 min then die and not restart)
2. As soon as I put it in gear it dies and will not restart without starting fluid or letting it sit for abit; However as soon as it does restart it idles and the engine runs fine.
3. I do not have a fuel pressure gauge, but will get one if yall think that is the NEXT step.
Old 10-15-2010, 06:31 PM
hmm i assume no engine codes? a fuel pressure test would be the next logical step, i would think. i had an 88 suburban, and that is what it did when it ran out of gas. (a friend borrowed it and ran it out of gas a few times). so i would assume that a fuel pressure issue is the problem. i'm not sure what the specs rae though. i know autozone will rent you the test gauge. maybe they can tell you the specs as well.
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Old 10-15-2010, 09:37 PM
It actually had run out of gas about a day before this issue happened, but after refilling it the truck ran for about 20 miles. Could running it out of fuel messed it up? Air in the line or something?
Old 10-15-2010, 10:13 PM
it prob should have caught up by now. of course, running of of gas can damage the fuel pump. especially if it's got some age on it. also, running it out can cause it to suck up any grime in the tank. remember, any of that gunk in the fuel filter had to pass through the pump. maybe a good fuel system cleaner would help...
on my suburban, if it ran empty, i just did some gas in the TB while cranking and it would start up. never had an prolonged issues from it.
2001 Chevy Blazer
4.3L 5 speed manual
145k miles
146k miles
Old 10-16-2010, 05:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Running out of fuel or running very low is a fuel pump killer.
Fuel pressure specs are 9-13 lb fuel pressure.
Recheck the fuel filter for black stuff or orther stuff.
A bad fuel pump will sometimes put black stuff in fuel filter.
Best place to test fuel pressure on that one is at the fuel filter gas line fittings.
May need a adapter line to tap into filter fuel line.
Hook up gauge and check cold start pressure and engine running and or running on the road pressure.
You should see 9-13 lbs all the time from cold start to after 30 minutes running on road.
Full pressure with return line pinched shouls be around 16-20 lbs pressure.
Post back you pressure readings.
MT
please help 5.7 liter hawk713 Caprice 1 04-22-2010 08:05 PM
1996 gmc 5.7 won't start-no spark 600cuin Sierra 5 11-13-2009 12:03 PM
a CHALLENGE!! ('93 5.7 Intermittent no-spark) cmjj42 Roadmaster 3 05-06-2009 11:55 AM
01 jimmy 4.3L stalled restsrt after cool chobes Problem Diagnosis 10 06-24-2008 10:10 AM
c1500 5.7 stalling hfx_guy C/K 4 02-05-2004 08:23 AM
