Go Back   Automotive Forums Car Chat > Pontiac > Aztek
Old 10-13-2010, 04:56 PM
Kelsey92504 Kelsey92504 is offline
Question 2004 Aztek heater blower control
My wife's 04 Aztek's blower control only works on the off position. It doesn't work on any other setting. It blows on off, as if it was on the number 2 setting. She came home today and told me now it doesn't work at all. Is there a switch or something I can just replace, or do I have to replace the whole thing. The hot and cold setting and the other knob work fine just the blower setting doesn't work. Thanks in advance.
Old 12-10-2010, 06:06 AM
Silverado6x6 Silverado6x6 is offline
Re: 2004 Aztek heater blower control
I know this is an older thread but it may help others, my wifes 2005 Aztek lost a couple of fan motor speeds, the problem may be a bad speed resistor module, it sits between the blower motor and the firewall, it cost around $30 or so, not too hard to remove but installing is a bear because the two back screws are nearly impossible to get at, I just backed them off enough to slide the slotted new part past them and then tightened the front screw down. You do have to remove the blower motor but its easy.
That is easier and way cheaper than the list $350+ climate control module....which could be the real problem, I think some of the reasons the blower speed resistor is burning out is because the cabin air filters (2) get all plugged up, they are behind a couple of panels in the back of the glove box.
2002 Silverado 3500 extended cab 4x4 dually
8.1 (496cid) Vortec, Allison 5spd w/OD
All front lights, fog lamps converted to 5000K HID, all running lights chip LED
Modded from LED sign double row red LED sequential T/S, running and brake lights mounted below tailgate.
New side and rear modded emblems for visual effects.
Escalade instrument cluster and auto dim LED outside mirrors.
Front and rear concealed amber Tomar strobe system
Modified for Alaska extremes
06 escape blower fan switch milo42gpw Escape | Maverick | Escape Hybrid 1 03-26-2009 06:38 PM
2004 caravan Front Heater blower not working papascott Caravan | Voyager 1 01-05-2009 11:31 PM
Heater/AC Blower Control Switch kidtau Caravan | Voyager 2 01-02-2009 01:18 PM
2004 Savana heater blower will not stop Dan-P General Discussion 0 05-12-2006 09:17 PM
1994 Passat Heater Blower Controls springpaul '93 - '96 2 06-30-2004 07:33 AM
