Old 01-05-2009, 03:59 PM
papascott papascott is offline
2004 caravan Front Heater blower not working
Just had a new battery installed ,now front heater blower not working. 40 amp fuse checked good.
Old 01-05-2009, 11:31 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2004 caravan Front Heater blower not working
Try disconnecting the battery again for 2-3 minutes. This will reset the system. Still won't blow? Could be the switch, relay, blower control module or resistor block, or the motor itself.
You have a resistor block and a blower relay if you have manual temperature control. You have a blower control module and a relay if you have automatic temp control.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
homefree (03-05-2011)
