Old 10-13-2010, 04:20 PM
gsal86 gsal86 is offline
Electrical/Starting Problems
Lately my 2000 grand prix has had some wierd electrical issues. I took my car to interstate batteries where my battery is from (new in july 2009) and he told me it was not a battery problem. Another battery shop said my alternator was ok as well
So the problem is: it has had a hard time starting up lately i.e. turining over takes about 3-5 seconds before it starts running, and today I was at the store and tried to start it, it lost power before I could hear it turn over. I sat there for about 5 minutes with no power and then power came back and I was able to drive away.
I did replace my ignition switch about 6 weeks ago, I made all the proper connections so my guess is it is not the problem...any help would be great.
Thanks,
Old 10-13-2010, 08:30 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Electrical/Starting Problems
I would check the battery connections for corrosion. Make sure you pull them apart.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-14-2010, 09:30 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
How did interstate determine the battery was not the cause, did they actually test it, and if so, did they test it on the car or did you take the battery to them after removing it from the car? Also, did you see any security warning lights on the dash when the car lost power/wouldn't start?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-14-2010, 11:50 AM
Thanks Blake!
Rich: The interstate shop tested it while still connected to the vehicle. I also had batteries plus test it and both shops said it was good. Well, batteries plus kind of tried to sell me a battery but i was watching the test and it was good. I think it is just a loose connection because today it didn't start again and i then wiggled the negative terminal and got power back. Thanks!
Electrical Starting problem Kolea '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 09-30-2005 01:31 PM
95 Cutlass Supreme electrical/starting problems bheston Cutlass Series 2 08-14-2005 10:25 PM
94 Jetta electrical/starting problem fundiablo '91 - '96 1 07-08-2005 08:37 PM
Trouble shooting electrical/starting problems for 2003 Windstar shu001 Windstar 4 03-16-2005 02:30 PM
