Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-12-2010, 06:01 PM
EngineandJuice EngineandJuice is offline
Car gets no Juice
Hey I have a 89 with a 350 and I'm getting nothing at all. The battery is good and that's where it stops. Last sunday I tried to start it and got clicking and lights flickering as if i had a loose battery terminal. Second attempt to start it fired right up. Today I tried to start got nothing. I never checked the terminals so i tightened them down tried again nothing. I have no lights, no ignition noise, no noise as if the starter is trying to turn nothing. Everything is dead.
I have no clue what the problem is my friend checked to see if there were any loose or disconnected wires everything is fine.
Old 10-12-2010, 07:52 PM
j cAT j cAT is offline
Re: Car gets no Juice
with a voltmeter and a helper turning the ignition on to crank find out where the voltage drops. could be wires at starter or a defective battery/corroded cables to it.
Old 10-12-2010, 08:20 PM
Blue Bowtie's Avatar
Registered Offender
Check the wiring at the starter. An '89 probably still has 2 or maybe 4 fusible links connected to the main battery terminal at the starter. Any connection problems there can cause those symptoms.
Old 10-23-2010, 02:40 PM
Well finally got around to doing this and I get 12.4v at the battery and 0.05 ??? at the starter is this right?
Old 10-23-2010, 06:23 PM
the wire to the starter should conduct the full battery power. these wires have fuses in them. these are wire fuses that over time corrode [turn green] they are cylinder shaped check by probing the wire on each side to see if these are open/high resistance/voltage dropping ...
Old 11-23-2010, 09:18 PM
So not having the time or the patience to attack this problem I took it to the shop. The problem was the ground wires. The guy ran a new ground wire from the battery to the engine and ran a secondary ground wire also no problems after that and it only set me back $114 which I would've happily paid if I had known I would be without a car for 3 weeks.
Old 11-24-2010, 12:28 PM
this is not a complicated circuit to find the problem . you did the correct action to have a shop repair this for you. 100.oo is a good deal..
remember you need a good ground ..many irnore the ground connections or wiring..just probe the positive feed wires..this can trick you.
Another car company get serious about electric cars - TECH.BLORGE.com Automotive News Automotive News Desk 0 11-26-2006 10:10 PM
Accaimīs starter not getting juice! eddie32818 Acclaim 2 10-27-2003 11:16 AM
