Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 10-12-2010, 03:05 PM
maldorasi maldorasi is offline
94 Continental Ignition Key won't turn
Brand new to this forum, but no stranger to fixing cars. Tried searching for the answer before posting, but no luck so here goes my first post. The ignition key on my 1994 Continental often gets stuck in the lock position. It has nothing to do with how the steering wheel is positioned. If you play with it and wiggle it enough, it will eventually turn and start. The same thing happened with my 2000 Jeep, I was able to find out how to remove the cylinder(2 screws to open the steeering column and you push a button to remove the whole lock assembly). Took it to a locksmith and for 20 bucks and 20 minutes it was better than new. The springs in the lock were getting stuck. So my question is does anyone know how to get this thing out.
Old 10-31-2010, 10:34 PM
Towncar's Avatar
Towncar Towncar is offline
Re: 94 Continental Ignition Key won't turn
Here's what the FSM says:
Two processes depending on whether or not the switch will turn.. worst case last
«1994 Continental Table of Contents»
«Group 11: STEERING SYSTEM»
«Section 11-04: Steering Column»
«REMOVAL AND INSTALLATION»
Ignition Switch
Functional
Removal
1. Rotate ignition switch to RUN position. Using a 1/8-inch drift, depress lock cylinder retaining pin through access hole and remove lock cylinder.
CAUTION:
Carefully note the position of the bearing retainer prior to removal.
2. Remove blue plastic bearing retainer by inserting a screwdriver or similar tool, with a 90 degree bend on the tip, between bearing retainer and bearing and by prying upward.
3. Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees. Remove bearing.
4. Remove lock drive gear. Carefully note relationship of lock drive gear to position of rack teeth.
Installation
1. Position lock drive gear in base of ignition switch lock cylinder housing in the same position as that noted during removal procedure. The position of lock drive gear is correct if last tooth on drive gear is meshed with last tooth on rack.
2. Position bearing retainer in ignition switch lock cylinder housing. Insert tip of a screwdriver into Double-D slot of bearing, then rotate 90 degrees.
3. Press blue plastic bearing retainer into lock cylinder housing. Ensure retainer is in its original position.
4. Line up flats of drive gear with flats of washer by pulling down on the column lock actuator.
5. Install ignition switch.
6. Check for proper start in PARK and NEUTRAL. Also, check to ensure start circuit cannot be actuated in DRIVE or REVERSE positions and the column is locked in LOCK position.
Ignition Switch
Non-Functional
The following procedure applies to vehicles in which the ignition switch is inoperative and the ignition switch cannot be rotated due to a lost or broken ignition switch key, unknown key number, or a lock cylinder cap that has been damaged and/or broken to the extent that the ignition switch lock cylinder cannot be rotated.
Removal
1. Disconnect battery ground cable.
2. Remove steering wheel as outlined.
3. Using channel lock pliers or vise grip pliers, twist lock cylinder cap until it separates from the ignition switch.
4. Using a 3/8-inch diameter drill, drill down middle of ignition switch key slot approximately 44mm (1-3/4 inch) until ignition switch lock cylinder breaks loose from breakaway base of lock cylinder. Remove lock cylinder and drill shavings from lock cylinder housing.
5. Remove retainer, washer, ignition switch and actuator. Thoroughly clean all drill shavings and other foreign materials from casting.
6. Carefully inspect ignition switch housing for damage from the above operation. If damage is apparent, housing must be replaced.
Installation
1. Replace lock cylinder housing, if damaged.
2. Install actuator and ignition switch as outlined.
3. Install trim and electrical parts.
4. Install new ignition lock cylinder as outlined.
5. Install steering wheel as outlined.
6. Check lock cylinder operation.
-Steven
1996 Town Car, Cartier
Ignition Key won't Turn Please Help Den S Durango 1 02-11-2007 10:50 AM
97 Cherokee ignition key won't turn pinger1ks Cherokee 5 07-04-2006 11:49 AM
2000 Malibu ignition key won't turn! Help! mdaly_2 Malibu 5 05-16-2006 08:43 PM
2000 STUPID METRO!..ignition key won't turn babyluv04 Metro 6 07-01-2004 08:51 AM
Ignition Key Won't Turn mkdotson Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 03-16-2004 01:43 PM
