Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 10-12-2010, 10:01 AM
LTZ89 LTZ89 is offline
94 deville engine code
I pressed off and warm for 3 seconds on the heater control with key on
it gave me code 288 on the speedometer.
does anyone know what code 288 means? it has a 4.9 engine it is not the contour
Old 10-12-2010, 01:08 PM
maxwedge maxwedge is offline
A990 racer
Re: 94 deville engine code
Check this link, http://myweb.accessus.net/~090/dtcobd1.html#dia
Old 10-12-2010, 01:47 PM
none of the codes in the list are there
after holding off and warm for 3 seconds the only thing that showed was 288
there are no letters before it.
Old 10-12-2010, 03:18 PM
A990 racer
Why are you checking codes was the cel on,?
Old 10-12-2010, 04:00 PM
the CEL is on
when car first started it is off then within a few seconds comes on and stays on
the 02 sensor went on it recently and was changed and now engine has plenty of power and idles where before it was stalling at every stop and wouldn't go over 17MPH up a hill
the light has been on for some time now and i wanted to see if i could get it to turn off
the car also had a new fuel pump assembly and distributor installed as well as the coil, and wires.
it has a problem where when you first go to start it the starter barely moves and the lights go dim but if you try it a few times it will crank and start and sometimes it just cranks normally the 1st time
the starter was replaced about a year ago and the battery is brand new
i appreciate all of your help with this matter
the car needs to be junked but he can't afford to replace it yet
Old 10-12-2010, 06:48 PM
A990 racer
Have the battery load tested, check for corroded cable ends and grounds if all ok usually the starter is the issue.
L59 Z engine code and LM7 T engine code......difference????? wirles Silverado 5 10-04-2010 03:14 PM
Engine Coolant and Heater on a 1990 Cadillac DeVille? butturinij@uwplatt Deville 2 11-03-2009 09:04 PM
96 deville trouble code justinsz8 Deville 9 07-14-2005 09:31 AM
91 deville diagnostic codes willh84 Deville 1 01-13-2005 03:48 PM
1993 Deville Engine light Mr.JP Deville 1 08-07-2004 06:08 PM
