Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 03-31-2005, 11:17 AM
justinsz8's Avatar
justinsz8 justinsz8 is offline
96 deville trouble code
I need some help from you cadilac guys. my friend has a 96 deville that put out a trouble code. had autozone retreive the code off of the computer, but they don't know what it means, or what exactly is wrong! the trouble code says Auxillary Emissions Control code. any ideas?
Old 03-31-2005, 08:07 PM
M.A.C M.A.C is offline
Which code is it? There should be a specific code. Are you sure the Autozone person knows what he's talking about. Make sure you see the code yourself.
Auxiliary Emission Controls
P0400 Exhaust Gas Recirculation Flow Malfunction
P0401 Exhaust Gas Recirculation Flow Insufficient Detected
P0402 Exhaust Gas Recirculation Flow Excessive Detected
P0403 Exhaust Gas Recirculation Circuit Malfunction
P0404 Exhaust Gas Recirculation Circuit Range/Performance
P0405 Exhaust Gas Recirculation Sensor A Circuit Low
P0406 Exhaust Gas Recirculation Sensor A Circuit High
P0407 Exhaust Gas Recirculation Sensor B Circuit Low
P0408 Exhaust Gas Recirculation Sensor B Circuit High
P0410 Secondary Air Injection System Malfunction
P0411 Secondary Air Injection System Incorrect Flow Detected
P0412 Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413 Secondary Air Injection System Switching Valve A Circuit Open
P0414 Secondary Air Injection System Switching Valve A Circuit Shorted
P0415 Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416 Secondary Air Injection System Switching Valve B Circuit Open
P0417 Secondary Air Injection System Switching Valve B Circuit Shorted
P0418 Secondary Air Injection System Relay ‘A" Circuit Malfunction
P0419 Secondary Air Injection System Relay "B’ Circuit Malfunction
P0420 Catalyst System Efficiency Below Threshold (Bank 1)
P0421 Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
P0423 Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424 Heated Catalyst Temperature Below Threshold (Bank 1)
P0430 Catalyst System Efficiency Below Threshold (Bank 2)
P0431 Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432 Main Catalyst Efficiency Below Threshold (Bank 2)
P0433 Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434 Heated Catalyst Temperature Below Threshold (Bank 2)
P0440 Evaporative Emission Control System Malfunction
P0441 Evaporative Emission Control System Incorrect Purge Flow
P0442 Evaporative Emission Control System Leak Detected (small leak)
P0443 Evaporative Emission Control System Purge Control Valve Circuit
P0444 Evaporative Emission Control System Purge Control Valve Circuit
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446 Evaporative Emission Control System Vent Control Circuit Malfunction
P0447 Evaporative Emission Control System Vent Control Circuit Open
P0448 Evaporative Emission Control System Vent Control Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450 Evaporative Emission Control System Pressure Sensor Malfunction
P0451 Evaporative Emission Control System Pressure Sensor Range/Performance
P0452 Evaporative Emission Control System Pressure Sensor Low Input
P0453 Evaporative Emission Control System Pressure Sensor High Input
P0454 Evaporative Emission Control System Pressure Sensor Intermittent
P0455 Evaporative Emission Control System Leak Detected (gross leak)
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel Level Sensor Circuit Low Input
P0463 Fuel Level Sensor Circuit High Input
P0464 Fuel Level Sensor Circuit Intermittent
P0465 Purge Flow Sensor Circuit Malfunction
P0466 Purge Flow Sensor Circuit Range/Performance
P0467 Purge Flow Sensor Circuit Low Input
P0468 Purge Flow Sensor Circuit High Input
P0469 Purge Flow Sensor Circuit Intermittent
P0470 Exhaust Pressure Sensor Malfunction
P0471 Exhaust Pressure Sensor Range/Performance
P0472 Exhaust Pressure Sensor Low
P0473 Exhaust Pressure Sensor High
P0474 Exhaust Pressure Sensor Intermittent
P0475 Exhaust Pressure Control Valve Malfunction
P0476 Exhaust Pressure Control Valve Range/Performance
P0477 Exhaust Pressure Control Valve Low
P0478 Exhaust Pressure Control Valve High
P0479 Exhaust Pressure Control Valve Intermittent
P0480 Cooling Fan I Control Circuit Malfunction
P0481 Cooling Fan 2 Control Circuit Malfunction
P0482 Cooling Fan 3 Control Circuit Malfunction
P0483 Cooling Fan Rationality Check Malfunction
P0484 Cooling Fan Circuit Over Current
P0485 Cooling Fan Power/Ground Circuit Malfunction
Old 04-01-2005, 08:01 AM
justinsz8's Avatar
Re: 96 deville trouble code
I just asked him about it, they didn't give him the print out from it. I guess he'll have to do it again and tell them that he wants to keep the print out.
Old 04-11-2005, 02:01 PM
caddydaddy caddydaddy is offline
On that car, you should be able to press and hold the "off" and "warmer" buttons on the climate control, then it will display the codes.
2000 Cadillac STS
2005 Cadillac Escalade
2008 Triumph Sprint ST 1050 ABS
Old 04-13-2005, 02:25 AM
mickster mickster is offline
what's up m.a.c., mickster hear i have a 98 deville that has a stalling problem looking to find out the meaning of these codes i pull off the on board dash computer. Is thery a web site i could go to and get the info please advise...
Old 04-13-2005, 08:53 AM
http://myweb.accessus.net/~090/dtcobd2.html
2000 Cadillac STS
Old 06-09-2005, 09:21 AM
muhsyah muhsyah is offline
96 sedan deville question, wont pass emissions test no codes showing, and passed everything but HC what could it be?
Old 06-09-2005, 09:24 AM
Re: Re: 96 deville trouble code
How is the general tune of the car? Does it need a tune-up, new air filter, etc?
2000 Cadillac STS
Old 06-09-2005, 03:34 PM
Re: Re: Re: 96 deville trouble code
i just purchased te car two days ago, and everything seems to be in order they just had an oil change, the inspector said try the spark plugs so thats what im gonna try first hope its nothing serious
Old 07-14-2005, 09:31 AM
2001bluebird 2001bluebird is offline
Banned
Re: Re: Re: Re: 96 deville trouble code
My Uncle ownes a car repair shop and his best advice is to do a full tune-up(if you can afford it) when you buy a car. B/C many times a dealer will make the car look up to date when it is not.
JUST MY 2 CENTS
