Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 10-12-2010, 09:19 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Fuel filter change, now service engine soon light
Hey guys,
I recently replaced a clogged fuel filter and now the SES light comes on after starting my '87 Caprice estate 307. Let me walk you through what I did:
1. The car had been rough starting and finally wouldn't start at all after repeated attempts.
2. Took off the air cleaner and snorkel hose and looked into the carb while opening the throttle and noticed that gas was not reaching it.
3. Disconnected the distributor bat cable and then disconnected the fuel line and saw that gas was coming out when the starter motor was operated.
4. Removed and replaced the clogged fuel filter.
5. Replaced air cleaner and all hoses.
The car seems to run fine now, except for the fact that the SES light trips after startup. Anyone have any idea why this could happen?
Thanks,
Alex
Old 10-12-2010, 09:28 AM
j cAT j cAT is offline
Re: Fuel filter change, now service engine soon light
Originally Posted by ASJT3 View Post
Hey guys,
Thanks,
Alex
with this engine I'm guessing its the O2 sensor. I would get the failure code and post this here for what is wrong.
the reason I say it may be the O2 is , this would cause the engine to run very good with the O2 not correct in operation .
I would replace the fuel filter after a few thousand miles . these metal fuel tanks with alcohol are a big problem with rust generation. If you have the old filter use a magnet to see if it is rust .
add a few ounces of marvel mystery oil to each fill up, or 1-2 ounces per 10gallons of fuel. this will clean up and protect from future tank corrosion.
Old 10-12-2010, 11:55 AM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Have the car checked for codes and post back your findings. It's really hard to guess what it might be..
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-12-2010, 12:43 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
I agree with Blt2Lst above, check the codes. You mentioned that you disconnected some wiring from the distributor. Check the 4-wire connector to the distributor to make sure it's making good contact. If it's disconnected, this is your light.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-12-2010, 09:30 PM
Alright guys,
Checked the codes and here's what I have:
21: Throttle position sensor high during idle or decel.
44: Lean exhaust indication
Old 10-12-2010, 11:05 PM
Blt2Lst's Avatar
Alright guys,
Sounds to me like you may have carb issues. I had the same codes before i had my carb rebuilt last December, turns out the TPS was bad and a worn throttle shaft caused a vacuum leak causing my lean condition. The worn shaft is common to the q-jets. The carb rebuilt took care of those problems along with my unsteady idle.
If you are going to take the carb apart to replace the TPS, you might as well do a complete rebuild.
Also, check all the vacuum lines (and there are a lot of them), chances are they need replacing also.
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-13-2010, 08:32 AM
Thanks Blt2Lst, can you or anyone else point me to a good reference on rebuilding the carb? I have the Haynes manual but not sure if that is enough by itself.
Also, how long can the car be driven in this condition/is any harm being done to it driving like this?
Much thanks,
Alex
Old 10-13-2010, 08:51 AM
Scrapper Scrapper is offline
AF Premium User
unplug your o/2 and see if any change. have you tryed resetting your computer? if not take neg cable of for about 15 min. or so and it will reset your computer when you hook cable back up.
Old 10-13-2010, 01:05 PM
NOVAZ27 NOVAZ27 is offline
HELLO. In your initial post you stated that your engine was a 307 (OLDS ENGINE maybe?). Is this what you have? Or do you have the CHEVROLET 305? Is the carb a 2bbl or a 4bbl? This info might or might not make a diffrence in the expertise within the replies you receive. When the O2 sensor went bad on my 84 CAPRICE it did not throw a code via the SES light. It just ran like it was starving for gas, good idle but on a hard/steady pull it would just lie down, cut out etc.
HOPE THIS HELPS
CURRENT VEHICLES
"84" CAPRICE
"86" SILVERADO
"06" GRANDPRIX GT
VEHICLES IN LIMBO
"69" NOVA SS
"72" CHEYENNE CUSTOM CAMPER
"80" CITATION
"85" SAFARI
Old 10-13-2010, 01:58 PM
Blt2Lst's Avatar
The Olds 307 came with the Q-Jet carb.
A rebuild kit usually comes with directions and a exploded assembly diagram.
The TPS is a separate part not included in the kit. Also, if the throttle shaft has excessive play, you would need to get a bushing kit which would also include a reamer of the correct size.
Or you could have someone else do the rebuild.
These are the guys that rebuilt mine.
http://www.smicarburetor.com/product.../productID/432
1992 Camry LE 2.2
1996 Suzuki RMX250
Old 10-13-2010, 02:35 PM
SHAWN MURPHY INCORPORATED. Good stuff. Check em out on the web.
CURRENT VEHICLES
"84" CAPRICE
"86" SILVERADO
"06" GRANDPRIX GT
VEHICLES IN LIMBO
"69" NOVA SS
"80" CITATION
"85" SAFARI
Old 10-13-2010, 02:58 PM
krivasauto krivasauto is offline
Banned
+1. And great prices.
Hoses, Coolant, Thermostat and Sensor replaced. Now get Service Engine Soon light MarkNYC Montana/Montana SV6 2 12-31-2009 02:12 PM
Service engine soon light. Engine codes RK4332 Grand Marquis 2 09-20-2006 03:55 PM
Steering wheel locked up, Service Engine Soon light, Flickering head lights AnimalDrMarshall Aurora 2 06-01-2006 10:49 AM
89 camaro engine trouble...service engine soon light Cbballplaya Camaro Discussions 17 10-24-2004 04:02 PM
Service Engine Soon Light and Service Light bowmanslandscaping SC/SL/SW 3 05-03-2003 02:43 PM
