Old 10-11-2010, 05:08 PM
wldleak wldleak is offline
Do I replace head gasket on 96 3.9 Windstar?
My "96" 3.0 has 219k miles. I do all the maintenence on it. I keep up with all the oil changes and nessecary repairs. Recently my radiator blew a o-ring at the bottom of the plastic tank. It blew when I was driving on the interstate and noticed when I turned on the heater no heat came out and I smelled antifreeze. Shortly after it was running a little rough. I pulled off on the next ramp and saw fluid all over in engine. Van sat for a week before I replaced the radiator. It was only 2 1/2 years old. Parts store replaced it on lifetime warranty. After the radiator was replaced engine ran rough. I checked plugs and they were at 60-65ths. 20 over so I replaced plugs and wires, they were due. Also, plugs were not wet at this time. I also recently replaced thermostat, lower ball joint control arm and belt tensioner. The mechanic wants $1020 to replace headgaskets and send heads to a machine shop for re-work and valve seals. My delima is, is it worth doing the head gaskets. This van is a second weekend receational vehicle for me. It's not worth more than a $1000. I hate to give it up, but don't want to sink a lot of money in only to have a lot of furture problems. Any advise would be apprecieated. Should I do the work my self?
Old 10-12-2010, 07:00 PM
wiswind wiswind is offline
Re: Do I replace head gasket on 96 3.9 Windstar?
Are you sure that the head gasket needs to be replaced?
Do you need to add coolant? (remember, it can take a while to burp the air pockets out of the system).
Coolent in oil (www.blackstone-labs.com)?
Head gaskets are not a common failure on that motor, I am guessing you are thinking that way because of overheating?......but it takes quite a bit of overheating to do that.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-13-2010, 08:51 AM
Re: Do I replace head gasket on 96 3.0 Windstar?
I have now have water in the oil and oil comming out at valve cover gaskets. Took it to mechanic and he did test to confirm. He called it a head test theough the radiator.
Old 11-04-2010, 08:23 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Question Re: Do I replace head gasket on 96 3.9 Windstar?
I don't know about the 3.0s but the 3.8s had headgasket problems on the 95s. Newer 3.8s have trouble with the intake manifold gaskets going bad.
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 11-04-2010, 08:25 PM
danielsatur danielsatur is offline
I would give http://www.steelseal.com , a try!
If it don't work, you can get your money back.
do a google ''youtube auto steelseal''
2000 windstar intake oil leak,should I replace head gaskets while Im at it? mustangmanic73 Windstar 3 03-26-2009 10:05 PM
replacing head gaskets 3.8 engine Btd36 Silhouette 2 06-15-2005 03:06 PM
Replacing head gaskets ~ 95 GPSE 3.1 10YrOldGPSE Grand Prix 0 04-12-2005 08:26 PM
Replacing Head gaskets on Ford 3.8l engine Dngrsone Windstar 3 11-02-2004 11:01 PM
Replacing Head Gasket on 4.3 mikerae C/K 0 06-04-2004 04:07 PM
