Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 06-13-2005, 09:12 PM
Btd36 Btd36 is offline
Unhappy replacing head gaskets 3.8 engine
Anybody know of a easy way to pull the rear head off of a 3.8 engine. And should I have the heads checked out in the shop?
Brian
Old 06-13-2005, 09:56 PM
cdru's Avatar
cdru cdru is offline
Re: replacing head gaskets 3.8 engine
Can't help with the removal on the 3800, but any time you have the heads off it would be very foolish NOT to have them checked at a minimum. It may cost a few bucks but do you really want to redo it down the road if there was a problem with it?
Old 06-15-2005, 03:06 PM
94 Jimmy 94 Jimmy is offline
Check out the Haynes Manual for your Van, it costs about 20 bucks and is worth every penny.
I just did the head gasket on my 1998 3.4, it's not a joy, but it's possible if you take your time and lots of pictures. On the 98 you have to rock the engine forward, if that's what you have to do on yours also, remember that if the rope holding the engine forward lets go and your arms are back there, it will porbably break them, double up on the tie down straps used to rock the engine forward.
Regarding the shop check, I found a crack between the intake and exhaust ports in #6 cylinder. I had it checked out and all of the intake valves were leaking and the valve seals were leaking oil. Both heads cost about $160 and about $180 for a gasket set (don't use FelPro, my last head gasket lasted only 50KMi)
Good luck, get that manual
See ya
94
