Old 10-11-2010, 02:19 PM
rx7king's Avatar
rx7king rx7king is offline
Airbrushing (possibly a stupid ??)
I have a airbrush however i seldom use it because i dont have the process down very well. I am curious, when you mix your paint and thinner do you mix only what you are intending on using right at that time? Or do you mix a fair amount of it for later use? I guess I am also wondering if thinned paint has a long shelf life if you do mix a jar of it? I think this is an issue that has held me back from airbrushing because I really dont want to waste a bunch of paint or mix small amounts of paint at a time. Any insight on this would be appreciated and sorry for the dumb question but i couldnt find any help from the search tool.
Old 10-11-2010, 03:41 PM
jano11 jano11 is offline
Re: Airbrushing (possibly a stupid ??)
Mix only what you use.
Old 10-11-2010, 03:46 PM
rx7king's Avatar
So basically the only efficient way to do it is to get a lot of the parts ready for paint and do a lot at once if you can?
Old 10-11-2010, 04:47 PM
ales's Avatar
ales ales is offline
Forza Schumacher
Really depends on whether you can still enjoy the hobby if it starts to resemble an assembly line I can
What I do, like Jano11 suggests, is mix exactly what I need for the particular airbrushing session. The exception here is semigloss black that I actually a lot of but that's only because it's probably the most widely-used colour that can be found on virtually any model, so it does not have the time to go bad. Most of the time.
Old 10-11-2010, 04:56 PM
stevenoble's Avatar
Just use a gravity feed airbrush with a small colour cup. You can mix minute quantities of paint and there is zero wastage at all. If you don't like mixing different paints up, then maybe airbrushing isn't for you. During the course of building a model, I will sometimes mix ten or more different colours in very small quantities. Once you get used to mixing, spraying, quick flushing the airbrush and mixing the next colour, it's no different than using a paintbrush and washing it out between colours.....
Steve Noble
Old 10-12-2010, 02:41 AM
CifeNet's Avatar
CifeNet CifeNet is offline
I mix and use at the time of airbrushing and this isn't a big deal.
I find that it is not an exact science, you have to go with flow and define your own method that works for you.
However, for custom colors, I did save them up to a couple of months. I had no issues using pre-mixed paint; I slightly added thinner to a level where it won't change the color shade and it went on okay...
-- CifeNet
Old 10-12-2010, 05:43 AM
klutz_100's Avatar
That's the critical factor IMHO.
With a gravity cup, mixing and cleaning is not much different from brush painting really - once you get the hang of it.
Combine that with Vallejo acrylics in their dropper/dispenser bottles and wasted paint really IS comparable with brush painting Also, I always put any unused thinned paint back into the jar - it does no harm at all (quite the opposite in fact)
I have never used a bottom-jar airbrush but I can imagine that they are much more of a pain to use for airbrushing small doses of color.
Old 10-12-2010, 06:06 AM
stevenoble's Avatar
Exactly right. I used to use one and it's a real pain to keep filling the jar and cleaning it out after each colour....
Steve Noble
Old 10-12-2010, 09:29 AM
rx7king's Avatar
Awesome, thanks for the input guys much appreciated
Old 10-12-2010, 10:14 AM
360spider's Avatar
Thinned paint goes bad in about 2-4 weeks, depending on paint. Some sooner some later.
ItalianHorses.net
Old 10-12-2010, 11:11 AM
klutz_100's Avatar
Mine doesn't
I think it depends on what you thin it with. A compatible thinner should not react with the paint. I've got jars of Tamiya paint that has been diluted with Tamiya thinners over 2 years ago and was still good when I used it yesterday on my Cayman
Old 10-12-2010, 01:40 PM
ales's Avatar
Forza Schumacher
But if you thin them with lacquer thinner (like so many of us do) then yes, they to turn into sludge.
Old 10-12-2010, 02:21 PM
klutz_100's Avatar
Like I said, compatible
Putting square pegs into round holes has to have some drawbacks somewhere I suppose.
Not that I think longevity of thinned, leftover paint is such a huge benefit worth more than using your preferred thinner. My motto is "if it works for you, go for it!"
Old 10-12-2010, 02:27 PM
drunken monkey's Avatar
Razor Sharp Twit
As habit, whenever i buy a new jar of Tamiya (X/XF) acrylic, I add a drop or two of their X-20A thinner. I've got a couple of these of colours that I don't use that often that are more than 2 years old with no noticable ill effect from adding their thinner.
I also have a jar of semi-gloss black (X-18) that I've over saturated with X-20A thinner that is perfectly fine.
AF's Guidelines
Read them.
Is it possible to airbrush Tamiya X & XF paints? adz13091982 Car Modeling 5 02-02-2009 11:56 AM
Possible stupid question... maney8295 Grand Prix 1 04-09-2008 07:01 AM
Possible Stupid Question roach2k2 Off-Topic 19 07-16-2004 09:51 PM
possible stupid question BlackDeath_Eclipse Off-Topic 1 04-08-2004 09:22 PM
Is it possible to airbrush primer on? crab Car Modeling 13 06-26-2002 06:48 PM
