Old 10-11-2010, 12:30 PM
pp270 pp270 is offline
main window switch
Does anyone know if the front drivers side main window switch on a 2000 grand prix gt is common with any other vehicle?
Or a low cost aftermarket source to purchase one?
Old 10-11-2010, 02:02 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: main window switch
I have a spair used one laying around somewhere for a 4-door.
Not sure if it works or not. I bought it used.
For 20.00 paypal its yours.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-11-2010, 06:45 PM
that sounds interesting. I have got two used ones from the bone yards and both havn't worked. I found that if the switches actuates and clicks in both directions then they are typically good. If the switch is soft when actuating it is bad. My current switch has the drivers window broken. How does yours actuate?
Old 10-12-2010, 01:30 AM
tblake's Avatar
In God We Trust
3 actuate fine, drivers is soft as you say. so its probably shot.
have you tried taking them apart and piecing them together to make one working one?
Old 10-12-2010, 09:25 AM
No I havn't. Do you know if that is possible. I will take a look at the spare and see if it looks like it will come apart.
Old 10-12-2010, 10:06 AM
tblake's Avatar
In God We Trust
I think it has little clips towards the back that you can use a small flat blade screwdriver to pry and pop the switch apart.
I will look at mine a little later and see.
Old 10-12-2010, 12:59 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The most common failure in these switches are the little ears attached to the button rocker that actually push the metal tangs down. You can move them from one position not often used (like the passenger rear) as a temp fix until you can get a replacement. I put a Dorman switch in my 99 4-door, and the only complaint I have is occasionally when you release the switch after putting the window up, it will click back tot he express down position and the window will go back down. It's less than 1/2 the cost of the GM switch and matches perfectly.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
93 regal 3 windows work 1 doesnt gmfan88 Regal 0 02-25-2009 01:00 PM
top brake light affected by main light switch aswjetta '97 - '03 0 11-18-2007 06:32 PM
P10 Glass, gas/trunk switch, rubber trim, handles, + window switch (7 total items) WinterG20 Classifieds 0 01-19-2003 09:42 AM
