Go Back   Automotive Forums Car Chat > Buick > Regal
Old 10-11-2010, 07:13 AM
capnrus789's Avatar
capnrus789 capnrus789 is offline
Dual Zone climate contol issue
My A/C seems to be stuck on for the driver side. The temperature side changes with no problems, blows how when the temp is craked up, blows cold when I set the temp low. The drivers side is always cold. After reading the forum and tryign the battery disconnect trick, I htink I probably have a bad driver side belnd door actuator. I'm wondering how difficult it's goign to be to replace this myself? I've never pulled dash trim off before, only a door panel. I don't want to break something.
How hard is this? Where can I find instructions to remove the necessary dash pieces to get at this thing?
'99 Regal LS 3800 Series II
'06 Subaru Outback Wagon
Old 10-15-2010, 10:27 PM
Drgsxr750 Drgsxr750 is offline
Re: Dual Zone climate contol issue
I have the same problem in a 98 Regal Gs. Where is the drivers side? I think I found the passengers side behind the glove box but I can't seem to find the drivers.....
Old 10-18-2010, 08:00 AM
capnrus789's Avatar
I pulled off the lower kick panel, there was just 2 plastic tabs holding it in. I had to climb under the steering wheel and with a flashlight I was able to see it. It's pretty high up there. No idea how I would ever remove it without tearing up the whole dash, though. Check the parts websites for a pic of it,you should be able to identify it. I'm going to shop around for a shop to do it. It's my only car and I can't afford to screw it up, especially with a Chicago winter around the corner.
2002 Park Avenue Ultra Dual Zone Climate Issue realatty Park Avenue 10 10-14-2007 07:24 PM
Dual-Zone Climate Control Light Repair bcook Monte Carlo 17 10-04-2006 04:19 PM
97 Lumina LTZ Dual Zone Climate Control Issue bigbandguy Lumina 4 07-28-2006 09:18 PM
Dual Zone Climate Control? CWW17 Camaro Discussions 0 01-18-2006 04:32 PM
dual zone climate control adalez71 C/K 1 11-04-2003 01:09 AM
