Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 10-11-2010, 02:07 AM
superkia superkia is offline
86 Nova occasional idle issue
I bought a 1986 Nova that has been sitting in a garage for around 20 years, the car only has 13k original miles. The owner dumped money into it but could never find the cause to their problem and after tearing everything apart we found that the clamps on the fuel lines were original and loose. After replacing the clamps, the car ran good.
Now the only issue I have with this car is that it stumbles like it wants to cut off when at stop signs and such but id only happens every once in a while. The car also will idle very high at times but with no tachometer I cant tell you how high.
The carburetor was cleaned out due to the black gunk from sitting but we still get the occasional stumble in drive at a stop or a high idle every once in a while. From searching the internet, I have only come to the conclusion that there is a small vacuum leak somewhere???
Anyone ever dealt with this proble and have any ideas on where I should start. When the car is driving it runs great, its just the stumble at stop and the high idle on occasion. The car smell of gas so I assume it it running rich but I am not mechanically inclined so it could be anything.
Any input would be appreciated,
Rich
FOR SOME REASON i CANNOT REPLY TO YOU BUT THANKS FOR THE INFO, I REALLY CANT FIND ANY INFORMATION ON THIS CAR ONLINE.
Old 10-11-2010, 11:53 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Re: 86 Nova occasional idle issue
You would likely get a better response to your question if posted in the " Corolla " section of the " Toyota " forum here on AF . The 1986 Nova was actually a Corolla in disguise , sharing all the mechanical pieces with the Corolla . The Nova body was somewhat different but the " kinship " between the two was obvious !
" Sometimes I grow so tired "
Old 10-16-2010, 05:28 PM
TommySS TommySS is offline
I've owned an 87 Nova, and am still the original owner of an 88 Nova (320k+ miles and still on the original drivetrain (including the clutch). I would install a carb rebuild kit first, and then (if no improvement) start replacing each of the many rubber hoses.
A stumble as you describe sounds like a bad accelerator pump.
Old 10-19-2010, 03:44 PM
Thanks for the reply. I have been having problems finding any information at all on this car even with the all mighty internet. I ordered a used haynes manual just so I could find out some basic information like oil capacity, fuel tank size etc. but it has yet to arrive.
From what I have found, once I can fix this issue, the car should last me a ton of miles considering the low mileage and great shape its in.
1995 mustang gt gt40 crate swap on going idle issues dcevil79 Mustang Problem Diagnosis 1 09-16-2010 05:35 PM
2004 ram 1500 4.7 overdrive and idle issues mrwrench Ram Pickup | Ram SRT10 2 06-03-2010 10:22 AM
starting/ warm idle issues thunderbirdcoupe89 Thunderbird 2 12-24-2009 10:36 AM
occasional various issues edbrycem TrailBlazer | Trailblazer EXT 5 09-21-2009 11:43 PM
Occasional starting issue - any suggestions? Setanta '88 - '91 Civic | CRX | Wagon | Shuttlee 2 03-04-2004 10:59 AM
