Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-10-2010, 04:51 PM
deanncaz deanncaz is offline
JGC 4.0 - Stalling in reverse
Help needed please!!
Over the last week, my 1999 JGC has started stalling when shifting into reverse. When I select reverse, with my foot on the brake no problem, it only stalls when I apply any pressure to the accelerator. After it has stalled in reverse, it is sometimes difficult to get it idling OK in Drive without stalling, always starts with the first turn of the key, but just dies.
Regards,
Deanncaz
Old 10-10-2010, 09:38 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: JGC 4.0 - Stalling in reverse
Has the local temperature changed?
How many miles?
Any other symptoms?
How long has it been since you put in a fresh set of spark plugs?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-14-2010, 05:09 PM
Thanks for your reply,
to answer your questions:
The outside temperature has only dropped a couple of degrees over the last few weeks.
it has covered 142k.
the only other symptoms are it is sometimes a bit sluggish through the gears.
and most embarrassing of all is i am not sure about the spark plugs, so i will be changing them this weekend!!
Regards,
Deanncaz
Old 10-14-2010, 07:44 PM
Post back after you put in the new plugs -- just a thought in addition; does it use any coolant?
Old 10-30-2010, 06:25 AM
I have just managed to replace the plugs. it now runs much better, but still cuts out when I select reverse!! with regards to the coolant, I replaced the radiator about 4 months ago, and since then i have lost no coolant. but just in case, i flushed the system today, but still cutting out.
Regards,
Deanncaz
1999 4.0 GC larado Cam and crank positioning sensor szellers73 Grand Cherokee | Grand Cherokee SRT8 4 01-19-2010 10:30 AM
93 Yj 4.0 starts with high idle... IntenzInc Wrangler 0 04-04-2009 12:06 PM
94 JGC 4.0 PCM Codes LELeach Grand Cherokee | Grand Cherokee SRT8 2 04-05-2008 04:20 PM
97 JGC 4.0 with a hose dangling *WHERE 2* Audiobahn77 Grand Cherokee | Grand Cherokee SRT8 2 02-18-2005 04:58 PM
99 JGC 4.0 reset pcm danielv Grand Cherokee | Grand Cherokee SRT8 1 02-13-2005 06:03 PM
