Old 10-09-2010, 03:14 AM
Albandy Albandy is offline
Send a message via ICQ to Albandy
Zero Paints Primer - No comment
Only this...
about 1 - 1 1/2 Years old, stored in a box, not exposed to heat or direct sun.
The paint is very thick and hardly to dilute properly.
In the garage is still a third bottle, too bad - no longer usable.
Andy
Old 10-09-2010, 06:24 AM
lotus123's Avatar
lotus123 lotus123 is offline
Re: Zero Paints Primer - No comment
It's fairly obvious that it's evaporated through those plastic bottles leaving the heavier stuff (technical term alert) behind.
The use of plastic bottles for these paints has been discussed frequently, and as most people now know it's shipped in those bottles to prevent breakage. You have to decant it into a glass bottle if you want to store it long-term.
My plastic-bottled Zero paints are stored in Ziploc bags INSIDE an airtight plastic food storage container and they've lasted for a few years. I just re-thin them slightly with Zero base coat thinners if necessary. Having said that, you have to stand back when opening the box because the fumes that accumulate in there will blow your sinuses apart.
Update - just checked my Zero stock and my grey primer microfiller looks like yours, because it wasn't in the airtight box! The packaging does say it can be thinned with basecoat thinners though, so maybe it's not a write-off.
Old 10-09-2010, 07:05 AM
oter oter is offline
have you read the zero paint f.a.q.?
How long does the paint keep?
As the paint is supplied Pre-thinned and thinners will evaporate over time, it should be fine for 6-9 months, if the thinners have evaporated you can add more basecoat thinners to bring the paint back to the original state.
Keeping the paint in a Cool, Dry Environment will greatly length it's life.
We also suggest only purchasing small quantities of paint at one time, rather that bulk buying and storing for long periods of time
Old 10-10-2010, 11:20 AM
stevenoble's Avatar
Buy what you need, when you need it. Although it might be better and save on postage and such, the paint does go off over time and no way can it be stored indefinitely, no paint can in fact. The majority of these paints are now supplied in glass jars and this does minimise the evaporation somewhat. It's not a problem with the paint. Remember these are automotive paints, not model paints and as such they do have a shelf life...
Steve Noble
zero paints on tamiya paints? gordonli1 Car Modeling 26 04-16-2015 10:46 PM
zero grey primer thinning required? kans0002 Car Modeling 2 03-23-2009 08:41 AM
Zero Paints Info patoffspyder Car Modeling 21 12-21-2008 05:13 PM
Zero Paints release Gulf Blue and Orange Paint Hiroboy Car Modeling 5 02-25-2007 03:03 PM
Zero Paints to Canada? patoffspyder Car Modeling 4 02-25-2007 02:35 PM
