Dodge Truck 1500 need help
I have a 1996 dodge 1500 pickup and just put a new rearend under it out of a 2002 dodge pickup with disk brakes and i cant get enough braking power to the rear wheel is there thing that may help fix the problem
Re: Dodge Truck 1500 neeelp
your 96 brake system was designed for drums on the rear. Your new rear disk brake calipers require more fluid volume than the origional drum wheel cylinders.
You might be able to fix the issue by modifying the proportioning valve, but you may have to swap out the master cylinder for one that was designed for rear disk brakes.
when all else fails, get a bigger hammer. ![]() Vehicles: 2005 suburban 1500 4x4 all stock, ex-fire department truck. 1987 Grand Wagoneer |
^^ spot on drum and disk don't mix!
