Old 05-20-2003, 03:59 PM
SwooshICE's Avatar
SwooshICE SwooshICE is offline
About the tamiya compressor..
hi, i m pretty much a modeling n00b,
but i m plannig to buy an airbrush and a compressor
i don't need anything super professional
as long as it gets the job done
i found this on hlj
http://www.hlj.com/cgi-perl/hljpage.cgi?TAM74520
would this be good enough??
if not please suggest others
thanks!
Keke!! -_-
Old 05-20-2003, 05:26 PM
modelcarmaster16's Avatar
modelcarmaster16 modelcarmaster16 is offline
yeah it will be good
Old 05-20-2003, 06:35 PM
theoldboy theoldboy is offline
shame you dont have a location entered
in australia you can get a good compresor from most auto stores for under $200.00 they are a lot better than the tamiya one
as for airbrushes never used a tamiya, i have a aztec + badger both very good. price depends on the type of airbrush you buy
i would look all the opptions that you have before you buy anything ,ask the people at your local hobbie shop or other people in your area or on this forem
it would help to know where you lived
Old 05-20-2003, 06:45 PM
nornicle nornicle is offline
Send a message via ICQ to nornicle
hrmm
The old boy, can you tell me where I can that compressor and what type it is?
Richard
nornicle@\/ahoo.comau <br>
Old 05-20-2003, 06:54 PM
SwooshICE's Avatar
i m in canada
Keke!! -_-
Old 05-20-2003, 08:00 PM
Jomnhta Jomnhta is offline
The Tamiya Spraywork is a very good entry level airbrush. I have used it for 5 years no problem. I dunno if they still come with 2 nozzles (thin and large)but mine (older version) does.
Old 05-20-2003, 08:30 PM
SwooshICE's Avatar
did u have to buy the battery also?
or did u use an adaptor instead??
Keke!! -_-
Old 05-20-2003, 09:30 PM
yellow15's Avatar
yellow15 yellow15 is offline
yeah i'm going to buy the tamiya one as well. I've talked to a few guys from local hobby shops, they all recommend me this and say it should be more than enough for me (a casual modeller)
I noticed it is backorder on HLJ thou so hopefully i don't have to wait too long
DRAW PHOTOGRAPHY
Old 05-21-2003, 02:05 AM
CYPH3R CYPH3R is offline
how much is that tamiya set??
i dont know how to convert yens
i live in hawaii
Old 05-21-2003, 04:52 AM
christofurr's Avatar
christofurr christofurr is offline
I bought one of these 3 weeks ago and it works very well. The first time I had ever used an airbrush and I got the hang of it straight away. It's very easy to use and to get the hang of it. The only tiny problem, is that the airbrush itself has a plastic body. This just means that you have to take extra special care of it, but it still feels pretty solid . Plus Tamiya have a range of pretty good quality airbrushes that you can move up into if you feel the need.
The compressor itself feels very solid and well build too. Mine came with an adapter which is a good thing because it's cheaper than having to buy the battery and charger, and you get unlimited running time .
Old 05-21-2003, 09:48 AM
Re: hrmm
try superchep auto or repco ,they are all made by the same company they just use different stickers, with a large capacity tank you only get your inital start up noise and and when it starts again to top up the pressure tank(not that often) its the best way to go ,those small ones are apain in the arse
Old 05-21-2003, 09:56 AM
maybe you should talk to someone whoes used airbrushs for a while most will tell you not to waste your money on that type of compresor
just because it has tamiya written on it doesnt mean its good
you Kiwis
go the crusaders
Old 05-21-2003, 09:59 AM
Originally posted by SwooshICE
i m in canada
is that a state of the USA
PatR PatR is offline
I have the older version of the Tamiya Spray Work.
Nice, simple PORTABLE compressor.
A couple R/C batteries and i'm set.
Rally Car Model Builders forum
http://rcmbforums.proboards70.com
Old 05-21-2003, 02:49 PM
hirofkd's Avatar
hirofkd hirofkd is offline
i live in hawaii
http://www.xe.com
Bookmark it, or just memorize it.
Hiroaki Fukuda
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
