Old 10-07-2010, 09:08 PM
CL8 CL8 is offline
Radiator fluid question
A student of mine said he heard if you put urine in a car radiator it will help cool the engine without ruining it.
Is this true, or just a lie he heard in a movie?
Thanks
Cl8
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 10-07-2010, 11:54 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Radiator fluid question
Uh... complete BS
Dragging people kicking and screaming into the enlightenment.
Old 10-08-2010, 12:33 AM
CL8 CL8 is offline
Thanks Curtis, that is what I figured.
I would guess the acid in the urine would not be good for the radiator.
Romans 10:9-10
Old 10-08-2010, 09:12 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
That is only done in an emergency when you have nothing else to pour in after you've run low on coolant. Definitely not recommended for normal use...I bet it smells awful, too.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-08-2010, 04:45 PM
CL8 CL8 is offline
Thanks JD
I still wonder if the acidic content would deteriorate the radiator or engine.
Romans 10:9-10
Old 10-09-2010, 11:07 AM
puterhead puterhead is offline
Urine would probably actually protect from freezing or overheating better than pure water, since its freezing point would be lower and its boiling point would be higher. I say probably, because I have no idea how it would react to being pressurized. Urine does have a high PH, so if used for an extended period, corrosion of steel and aluminum components would be expected. That said, why don't you give it a try and let us know how it turns out.
Old 10-09-2010, 03:55 PM
jdmccright's Avatar
The RustBuster
Urine has a pH of 4.5 to 8. The "coolant" would have to go outside that window to significantly increase the corrosion rate of aluminum (aluminum is amphoteric, meaning it can be dissolved by low and high pH solutions).
For steel, corrosion begins to increase at a pH below 4 and becomes passivated at pH above 10.
In short, you could probably run it for a reasonable time if needed, but given a scenario where you've lost significant amounts of coolant due to a leak and you're stranded otherwise, I'd take my chances with filling up with urine versus staying put in a dangerous situation. However, the rate of corrosion would increase because you've lost the protective additives provided by the real coolant.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 10-09-2010, 08:50 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Based on the capacity of a cooling system, you would have to have one huge, full bladder, to really even come close to making a difference in a low cooling system that is overheating.
-Rod
Old 10-09-2010, 09:41 PM
CL8 CL8 is offline
Thanks guys,
I told my student he would be better off calling for help rather than trying to drive with urine in the radiator, if for no other reason the smell would be terrible.
Romans 10:9-10
Old 10-10-2010, 10:18 AM
I read a story about this being done a couple of years ago, but it took the full bladders of about 8 college guys in an SUV.
Old 10-10-2010, 10:50 AM
Scrapper Scrapper is offline
AF Premium User
i've never heard that b/s but there is one thing if you mix antfreeze it could jell up on you.
Old 10-11-2010, 04:44 AM
CL8 CL8 is offline
How would antifreeze cause urine to jell?
Romans 10:9-10
Old 10-11-2010, 05:13 AM
It probably wouldn't, and that's gel, by the way.
Old 10-11-2010, 09:40 AM
jdmccright's Avatar
The RustBuster
True it would take more than one bladder to help in an emergency. Depending on the vehicle of course, most coolant capacities are in the range of 2 gallons for cars to 5-6 for trucks. But to just limp along the road in highest gear and lowest RPMs, 1 gallon or so would be sufficient. Find 8 bursting bladders of 1 pint capacity and you're in luck.
If I were stuck out in the middle of nowhere, I'd rather be driving in a rolling stink than sitting idle and baking in no-man's land. Would I likely have 7 friends along? Anope. But knowing my route, I would hopefully plan ahead enough to bring some water along.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2003 GMC Envoy XL
2000 Honda ST1100
Vehicle History:
Old 10-12-2010, 08:58 AM
AF Premium User
if you look back i never said urine would {gel} it up i said mixing antifrezze would gel up. do you go to I-U?
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
Trans Fluid Leaking Into Radiator Coolant Wheels555 Venture 1 03-04-2009 06:18 PM
Oil in the radiator and in the radiator fluid reserve tank douaty Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 08-24-2008 10:48 AM
Radiator fluid leaking. But where??? gonefast11 Integra 2 09-03-2003 02:10 PM
