Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 10-07-2010, 10:01 AM
jamesjedi jamesjedi is offline
Trans. Whinning or ZZZZZ Sound
Hi,
I am new here. I hope I can get some insight.
I have a 2002 Chev Venture van that is whinning or making a ZZZZZ sound. It sounds like it is coming from the transmission, or, in the very least, from the front. The sound is always there. I have no engine fault codes on my OBDII scanner. Wife says it is not shifting all that well. The sound does not increase with engine RPM's, it does increase with wheel speed. Problem is not intermittent.
I just jacked the car up and checked the wheel bearings by wiggling the tires at the 12 o'clock and 6 o'clock positions. They have almost no movement.
Any thoughts? Thanks.
Old 10-07-2010, 02:49 PM
merc81 merc81 is offline
Re: Trans. Whinning or ZZZZZ Sound
You can't check the bearing that way. Even completely shot, the bearing won't reveal itself by moving enough to feel. Bearings make a rumble sound that changes intensity as you drive around bends.
Tranny whine can be bad, bad, bad. I had one that whined for a couple years, but the whine increased with temp, and it shifted fine when cold. When that one finally did go bad the whine was very loud and it was there as soon as the van started when cold.
That lasted two days--then I had to have it towed home. It has a new tranny now.
Not what you want to hear I'm sure, but forewarned is prepared.
Old 10-07-2010, 03:25 PM
Thanks for the reply. It does not get louder when turning, I have driven it around in circles, both ways and have not heard any louder sounds. It is hard to diagnose because it only happens when driving.
Could it be these pressure valves that I have seen posted. I do not have any engine fault codes.
Old 10-07-2010, 09:12 PM
lesterl's Avatar
lesterl lesterl is offline
Is the trans fluid full? Is it frothy? Have you had the filter changed in the trans?
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 10-07-2010, 09:19 PM
Yes, I changed the fluids and filter. Fluid looks and smells OK. I am going to check the propellor shaft and the drive shaft/axel tomorrow. Not to sure what to look for, other than the obvious things like bolts missing and fluid leaking. Perhaps they would feel loose if worn?
Old 10-08-2010, 08:20 AM
What did you mean by that?
When the TCC solenoid needs to be replaced, you should notice hard shifts most of the time, but really bad after things get warm. It might get so bad that when coming to a stop from above 50mph the van can buck & stall because its still in gear.
The line pressure gets cranked up by the ECM trying to compensate for the stuck valve, but that only works for a while it seems, and that increased line pressure causes the whine most people hear when they have the TCC lockup problem. This usually sets a code, but I have gone for a month or more of hard shifting, and not seen the light come on.
Heat and dirty fluid make the valve problem worse, so a transmission cooler ($50) and fresh fluid/filter always helps.
There are no propeller shafts to check unless you have all wheel drive (in which case I retract everything I've said). The drive shafts run directly from the transmission to the wheel bearings. CV joints that go bad really ought to give themselves away as you turn the van.
Sounds like transmission to me.
Old 10-08-2010, 10:12 AM
The left side wheel drive shaft feels a little loose. There may be a little additional noise when turning. Yes, you right...it is front wheel drive. Silly me.
I may take it out to have a better look.
Old 10-08-2010, 10:42 AM
Get the van up to highway speed--drop it into neutral and coast for 20 seconds or so. Does the sound change with the drop in engine speed or does it remain the same? Wheel bearing and CV joints are your only source of sound/vibration in the driveline and those will be unaffected by engine rpms.
Transmission whine/shudder will track the engine rpm...
Old 10-08-2010, 12:51 PM
I did that last night. The sound stays the same. I am staring to think that this is the problem.
Clanking sound when I accelerate dr.d.575 LS | MKZ 1 08-05-2010 07:39 AM
Vibrations / sound at high speed Elias125 Engineering/ Technical 5 05-19-2010 06:05 PM
Clicking sound when braking - '97 SW1 w/Man. Trans. forthekids SC/SL/SW 3 08-27-2009 07:26 PM
Brand new alpines but sound is horrible. How do I fix it? prosportsdude33 Car Audio 9 05-13-2009 12:53 PM
99 TRANS AM premium sound ccfbnj86 Camaro Discussions 1 01-10-2005 08:35 PM
