| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
98 Overheating Again
1998 Cavalier 2.2L OHV
I've been trying to deal with a 2.2L that is overheating for no apparent reason. The engine was recently rebuilt (thought the head gasket blew). Turns out the head gasket was fine, so I rebuilt it, put new gaskets in it, etc.... So, I've been driving it around without a thermostat as the car overheats if one is in it. Today I finally decided to put it back in, and low and behold the car starts to run hot. (This is a NEW thermostat by the way). The car hovers around the 1/2 mark on the gauge at idle, temp increases to 3/4 of the gauge as you put load on the engine/drive it around. Heat output only happens on 3 of the 4 vents (Driver Left - Hot, Driver Right - Warm, Passenger Left - Warm, Passenger Right - Cold), and all hoses seem hot EXCEPT the lower radiator hose by the thermostat housing. The lower hose is luke-warm but not hot like the others. I'm starting to guess I've got a clogged radiator which can't move enough coolant fast enough. I'm also thinking the heater core due to the vent/heat issue, but I'm unsure if that's really the case due to of some vents getting hot and others getting only warm? Never had that happen before.... Any suggestions? |
Re: 98 Overheating Again
If its not a clogged radiator (guessing its not), its because the cooling system is not completely purged. I HATE chevy for no radiator cap etc... Its a common problem.
What I did was, pull the front horizontal hose that leads to the top radiator. Fill until water comes out. Then quickly put the hose back on. Then I disconnected the hoses one at a time, from the overflow tank and with a funnel pour water into it. Did it for each one except the bottom hose on the overflow. It should fill on its own. Squeezed the hoses everywhere. There is a bleed screw on the driver side in the metal tubes for the heater hoses , below the coil packs. I loosened it. Squeezed hoses, closed it on the squeezed hoses. Loosened my grip on the hose. Squeezed again with the bleed screw open-then close. Repeat repeat repeat. This not being completely purged is a common problem. I also had an electric heat gun that puts out high temp and directed it at the t-stat housing to open it sooner. Squeezed hoses, etc etc until both upper and lower hoses were same temp. Let it cool, then repeat it. I have a hard time getting it completely filled but this works for me. Also, since these cars tend to run hot and will overheat in hot weather when stuck in traffic, I put in a bypass switch to turn on the electric fan manually when I need it. Do check if your fan is really turning on. |
