Old 02-22-2005, 02:32 PM
Expando1 Expando1 is offline
Question Yep...overheating again!
I have a 1990 Honda Civic, sedan, 1.5L, 130K miles which started to overheat yesterday. The temp gauge climbed to the red bar on 'Hot' then would intermittently drop to normal range for a moment before climbing back up over and over. So I figured it was the thermostat getting stuck and would intermittently open when the pressure got to a certain point hence the intermittent drop in the temp guage. Well I changed the thermostat and gasket today, refilled the fluid coolant level, and took it for a spin. Wouldn't you know it, within 3 blocks...same problem. Popped the hood, the radiator fans are blowing like mad and everything is hot. What else should I consider?
Old 02-22-2005, 02:40 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
I had the same problem myself.. i had a air pocket in my coolant system, nextime u go out and start ur car up check and see if ur return line from (side) of the head to the radiator is hot.. if it isnt try putting more coolant into ur car and squeeze the hose that connects to the top of ur rad and after u squeezed and it filled try swueezing the return hose hope that works for ya.
Old 02-22-2005, 03:34 PM
V-K V-K is offline
Send a message via AIM to V-K
Re: Yep...overheating again!
There is a nut to bleed the air out of the system at the return line near the head, might make it easier to get all of the air out.
Old 02-22-2005, 03:36 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
if you've been working with hondas much at all you'll learn real quick once your car starts to overheat your head is going to wrap real fast and destroy the headgasket while its at it... I'd check the thermostat, and run a compression test if i were you, and make sure your coolant is filled properly.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 02-22-2005, 05:01 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yup you need to bleed the air out of the system first or else it will overheat
Team Lonely Drivers
Old 02-22-2005, 05:26 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
make sure that the hot water valve is open (turn heater knob to hot) when filling/bleeding.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 02-22-2005, 08:47 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
im willing to bet he has allready burnt the head gasket.......
gunnmen01
My other ride..... is YOUR MOM !!!!!!
