Old 10-06-2010, 11:36 AM
DonC10 DonC10 is offline
Question Dies while driving
Have an 01 Windstar that had starting problems. Alternator tested bad so replaced it and batt. ( stock batt. figured it was due ) anyway now the van dies while driving. Speed and miles driven vary when it dies. So changed fuel filter, pump, jumped out fuel safety kill switch swapped fuel pump relay, checked IAC with meter. Anyone have idea what it could be? P.S. After the van dies I put it in neutral and try to re start and it cranks but wont start, but if you turn the key off and re start it starts every time? Thanks
Old 10-06-2010, 11:39 AM
danielsatur danielsatur is offline
Re: Dies while driving
When it dies, do you still got lights + battery?
Old 10-06-2010, 01:51 PM
Just drove the van, and yes still have lights, radio, and other elec. and while driving engaged passing gear and from 40 to 85mph no hesitation and didn't die till came to stop and got back up to about 25mph.
Old 10-06-2010, 06:20 PM
wiswind wiswind is offline
I'm wondering if something is causing loss of power to the fuel pump.
You did not mention fuel filter, has it been changed?
IAC should not cause the vehicle to die while driving and then not start.
I normally will cause the vehicle to stall when you remove your foot from the accellerator.
Another thing to check would be the coil pack as those tend to fail on years around yours.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-07-2010, 03:29 PM
Yes I changed the fuel filter before changing pump. Will check coil pack and let you know how it goes. Thanks for the help.
Old 10-07-2010, 05:07 PM
Have your catalytic converters checked, a plugged cat will chock your engine out.
Old 10-08-2010, 08:40 PM
Read post from J.C. Robbins who had the exact same prob. and has replaced all the same parts with no luck, posted on 10/4. After the money I have put into this ...........van it might be a week before trying but will post whether it solves my prob. or not. Thanks for all the help.
Old 10-18-2010, 03:40 AM
captbaldo's Avatar
captbaldo captbaldo is offline
Hi. I have a 2002 that had the same problem. Started with the alternator dieing then this problem came up after. It's your powertrain control module (computer) that needs to be replaced. When the alternator died it must have fried the computer. Once I replaced it the problem went away. I also replaced all the other stuff that you did before figuring this out. Spent almost 3000 dollars and it all started with a dead alternator. I was able to find a used one for a decent price. Once it's replaced though, your keys have to be coded to the new computer or you won't be able to start the van. Hope this helps.
2002 Ford Windstar LX R.I.P. Jan 28, 2014
2008 Chevrolet Uplander LT
Old 10-23-2010, 08:32 AM
eroosa eroosa is offline
Does the vehicle stumble a bit before it cuts out? Is is always at lower speeds like backing out of your driveway or at a light or ramp? Is there any kind of squealing noise from the engine?
My van never stalled or died out until I started having problems with the cam sensor and synchro.
After replacement van runs great.
I also had NO check engine lights or codes displayed when I was having these problems.
'94 3800: dies while driving... jarl Trans Sport 5 11-29-2009 10:50 PM
2000 malibu dying while driving appleblossom Malibu 4 03-13-2005 07:06 AM
Jeep Cherokee 89' Turns Over but dies, eventually starts and dies while driving. forester6779 Cherokee 2 12-24-2004 01:16 PM
engine died while driving hbatt0usai Grand Cherokee | Grand Cherokee SRT8 1 10-25-2003 03:23 PM
engine died while driving hbatt0usai Engineering/ Technical 0 10-25-2003 02:27 AM
