Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 10-05-2010, 07:54 PM
venturenot venturenot is offline
Knock Knock sound left front wheel
Occasionally I get a loud Knock Knock from the left wheel when I accelerate from a stopped position. The sound is loud and rythmic just like someone giving two good knocks to a wooden front door. Any ideas? Occasionally it will happen on a turn.
Old 10-06-2010, 06:30 AM
merc81 merc81 is offline
Re: Knock Knock sound left front wheel
Sounds like the ball joint. Raise the van with a jack so the front wheel is just an inch or so high. Use a pry bar of some sort and put it under the tire, then lift the bar to pry the wheel inward as you do. The wheel should not yield to this effort and if it does, your ball joint is bad. I've never had anything else make that distinct 'knock knock' sound you describe. Loose/worn suspension points such as the rubber encased bolts on the swing arm might do it, but those are easy to spot visually and most people describe that sound as a rattle noise.
Noise from my left front wheel 1999 Corolla wmcot Corolla/Matrix/Voltz 2 10-14-2004 04:48 AM
2000 LT Blazer left front wheel hum dubltap Blazer 7 10-09-2004 12:47 PM
Left Front Wheel Noise MuthaTrucker Blazer 4 01-14-2004 08:52 AM
