2000 LT Blazer left front wheel hum
My 2000 LT's drivers side front wheel hums only when I turn right at any speed. It doesn't seem to matter if I am making a hard right turn or only slightly correcting when driving straight. Any help would be appreciated.
Re: 2000 LT Blazer left front wheel hum
You need to check your wheel bearing.
Thanks! I thought that may be what it is.
For the halibut, check both sides, they both went for the same ride.
Yip, bearing, jack up your left front and grab the wheel on both sides and push with your right and pull with your left and see if there is any play.
Thanks Blazer LT I'll get to it this weekend, too busy at work this week.
Yea, you will be essentially wiggling the wheel for play.
No play and not noise with rotation might meana CV joint is bad OR you need to redo you diff and transfer case fluids. |
Now the problem is. How do I get the front wheel hub assy. out?
