Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 10-05-2010, 05:01 PM
monk02 monk02 is offline
Antifreeze Leak
I am replacing the water pump on my GMC Jimmy 2001 4.3L. Somebody told me that the engine fan is spring loaded. Is this true ?
Old 10-06-2010, 08:35 PM
old_master's Avatar
Advisor/Moderator
Re: Engine Fan
Nope, not spring loaded. There is a thermostat coil inside that regulates the fluid in the clutch. If you look close, you can see the "tail" of the coil sticking out of the clutch. You'll need the special tool to remove the fan clutch from the water pump. Most auto parts stores rent/loan them.
You have to know how it works,
to figure out why it doesn't.
Old 11-20-2010, 06:00 PM
Re: Antifreeze Leak
I didn't find the correct location of the antifreeze leak. The water pump would probably have to be replaced soon anyway. I think I'm facing the same problem as 'kvn4 loosing antifreeze' posted on 11/14/10 with the source coming from the lower intake manifold. I'll let you know what happens. Thanks for the help.
HELP! 98 Jetta-Fan keeps running after engine is off Sunshine17 '97 - '03 3 01-17-2010 12:47 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
check engine light and engine fan justin0717 Grand AM 5 07-14-2004 08:32 PM
