Old 10-04-2010, 04:33 PM
3racer 3racer is offline
no defrost
my sons 98 s-10 will not blow out the defrost ducts. it blows out the other vents just fine, but when you flip the selector over to defrost nothing changes. any ideas on what to do?
Old 10-04-2010, 07:47 PM
old_master's Avatar
Advisor/Moderator
Re: no defrost
Under the dash... find the red and the blue vacuum lines coming from the back of the mode switch. They both go to the heat/defrost valve actuator. If I remember right, it's on the driver side, close to the transmission tunnel, and above the gas pedal. With the engine at idle, the blue vacuum line should have vacuum when the mode switch is in the MAX AC, NORMAL, BI LEVEL and VENT positions. There should not be vacuum in any other mode switch position. If vacuum is correct, the door might be stuck. Try to move the actuator shaft in and out by hand to move the valve, (door). Post your results.
You have to know how it works,
to figure out why it doesn't.
Old 10-06-2010, 06:49 PM
Re: no defrost
thanks i will give it a try and report back!!
95 blaser will not swich from defrost to heat stays on defrost or vent john31607 Problem Diagnosis 1 01-19-2007 09:35 AM
A/C and Defrost elfwizard '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 14 03-03-2004 11:21 PM
Rear Defrost Not Working 90civicrider '71-'87 Civic | CRX 12 01-09-2002 12:52 PM
Rear Defroster Auto On Philip 3 Series 2 01-05-2002 01:12 PM
Disabling the automatic A/C with defrost setting OffroadX Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 06-05-2001 03:18 PM
