Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 10-04-2010, 12:25 PM
saw85 saw85 is offline
2004 Mountaineer sensor issues
My 2004 4.6L V8 AWD Mountaineer has several issues that seemed to have popped up recently:
1. ABS light sporadically came on and off and now remains on
2. Door Ajar light comes on and off- doors are not ajar
3. Will not shift out of park unless I pump brake/ turn on and off vehicle multiple times.
I'm new to the Forum, so please let me know if I should include any additional information. Thank you for any help you can provide!
Old 10-05-2010, 06:37 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 2004 Mountaineer sensor issues
Welcome to the forum!
Please confirm that the light that's coming on is the amber "ABS" light rather than the red "Brake" light. If it's the red "Brake" light check the fluid level in the master cylinder. If the level is low, you either have a leak or your brake pads are worn and need to be replaced. Please don't just add fluid, but rather check the condition of the brake pads.
If it's the amber "ABS" light, then there are some slight differences between those with just ABS and those that also have the RSC/AdvancTrac. If yours has either of these, there will probably be a badge on the rear liftgate announcing such.
The door ajar light is pretty common and there are several posts on this forum related to cleaning or replacing the door pin switch located in the door latches or inspecting the wiring for the rear liftgate/glass. You might try the "Search this forum" feature for keyword 'ajar'.
Does the difficulty shifting from park happen pretty much all the time or only when parked on a hill? If only on a hill, then you might try setting the parking brake before shifting in to park and see if that solves the issue when trying to shift from park. If it's acts up when parked on level ground as well, then it might be the brake pedal switch that's causing the problem.
-Rod
99 Mountaineer speaker issues? Bigtrucklittleguy Mountaineer 8 09-16-2020 10:40 PM
2004 mountaineer climate control issues martin tyree Mountaineer 2 09-04-2010 04:28 PM
2000 Mercury Mountaineer Heater Issues... Rhubarb Mountaineer 4 12-24-2009 06:54 PM
2004 Mountaineer Firing Order pkucan Mountaineer 3 08-15-2009 04:15 AM
2004 Mountaineer Keypad Code embraer Mountaineer 2 06-27-2006 03:18 PM
Tags
abs , ajar , brake , mountaineer , shifting
