Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 05-07-2006, 11:23 AM
embraer embraer is offline
2004 Mountaineer Keypad Code
Hi,
I just bought a 2004 Mountaineer and I am trying to find out how to get the factory code for the door lock keypad.
I have searched the forums for both the Mountaineer and Explorer and many have said that the code is located in the back where the tire jack is. There is nothing there in my car as I have a third seat there.
I have also seen people being referred to a website find find the code, however the website is no longer operational.
Can anyone help me here? Any assistance would be appreciated.
Old 06-04-2006, 11:54 AM
jj76ta jj76ta is offline
Re: 2004 Mountaineer Keypad Code
solved the problem. Well the code for the entry pad for my 2003 Mountnier is on the ecm. The ecm is located behind the rear door on the passenge side. Remove the panel on the inside and you will see it. The panel is just clipped on and no tools are needed. The code is on the White label on the ecm. It is 5 or 6 digets and they are written large off to one side of the lable. After you enter the code it will unlock the drivers door. then push the 3 and it will unlock all doors, then if you want push 5 and the rear glass will unlock. probly some other fetures that it does if you can figure them out. Good Luck.
The Following User Says Thank You to jj76ta For This Useful Post:
fultom (07-27-2011)
Old 06-27-2006, 03:18 PM
magnum3456's Avatar
magnum3456 magnum3456 is offline
Banned
on ours...the code was in the owners manual in the front..its a little credit card lookin thing...and thatll have the code on it...you can change it from there
