Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-04-2010, 11:31 AM
barker23 barker23 is offline
Send a message via Yahoo to barker23
01 vibration during normal speeds
My 01 Century just had new tires(balanced) put on 3 weeks ago. I noticed a vibration in it now 2 weeks ago gradually getting worse. More so at 30 mph with gradually speeding up to 60. I took it back to where the tires were done and they rechecked the balance and made sure there wasnt any broken or slipped belts, they said all was okay with the tires. There is no vibration in the steering wheel at any speed. Anyone have any ideas what this could be caused from? Thanks.
03 Chevy Trailblazer LT EXT
04 Silverado Z71
88 Fiero Formula V-6
82 Chevy Corvette
07 Dodge Caliber
Old 10-05-2010, 02:45 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 01 vibration during normal speeds
does the vibration change when the brakes are applied (lessens or gets worse?), is it worse while accelerating or at steady speed?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-05-2010, 06:12 PM
Its worse while speeding up. Dont notice anything when applying brake.
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 10-05-2010, 06:40 PM
maxwedge maxwedge is offline
A990 racer
If not in the steering where do you feel it, I assume they rechecked the rear tires also?
Old 10-05-2010, 08:16 PM
They rechceked all 4 tires. It feels like the front is shaking to the right and the rear is shaking to the left, then visa versa, dont know how else to explain it. While speeding up I can actually see my legs shake back and forth a little from what the cars doing. Could it be my rear shocks?
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 10-05-2010, 09:52 PM
consultIII consultIII is offline
does it shake only on accelleration or even when cruising at 60?
possible engine mount.
Are the tires a quality brand tire; as I have had cheap new tires balance ok but they had excess radial tire variation. As the tires are now 3 weeks old, the tire plies have relaxed, you could now have them road forced balanced to confirm. Typically this condition would worsen with road speed.
Old 10-06-2010, 09:23 AM
It only shakes during acceleration, if cruise is set at 60 it doesnt shake a bit, but if you try to accelerate to 65 then it shimmys until cruise at steady speed again. Tires are a Goodyear 75000 mile.
04 Silverado Z71
82 Chevy Corvette
07 Dodge Caliber
Old 10-06-2010, 11:50 AM
A990 racer
If this is not a misfire symptom I would look at front axle shafts and all the engine /trans mounts. From here it is tough to diagnose this type of problem.
Old 10-07-2010, 05:10 PM
sounds like misfire as maxwedge has posted.
you could try loading the engine with the car stopped. with the engine running in drive, the car stationary. e brake on and nothing closeby to run into. apply service brakes and hold then load engine by gently applying accellerator briefly (5sec). this creates a load on the engine which increases spark demand.
Vibrations / sound at high speed Elias125 Engineering/ Technical 5 05-19-2010 05:05 PM
Vibration at high speeds uspres2020 Grand AM 4 07-19-2009 06:23 PM
Most likely result of timeing belt falure during normal highway operating mean specs. Lass2UMI LHS 1 08-10-2007 12:58 AM
Vibration/Noise when driving at normal speeds Navigator46 Accord/TSX/Accord Hybrid 7 06-17-2004 10:58 AM
slight vibration during acceleration trappie Cutlass Series 9 05-21-2004 10:30 AM
