Old 09-30-2010, 01:55 PM
jrlugo45 jrlugo45 is offline
jl audio amp issues.
I just inatalled a jl audio j2500.1 mono amp to power my two mtx jackhammer jh55 12's it powers the subs just fine i am useing 4ga power and ground as the amp calls for the amp also calls for a 60amp fuse and at first i was using a 100amp and the amp went into protect mode and was extremely hot., was the fuse the problem? i installed a 60 amp fuse and it has not gone into protect mode agian but the amp still gets quite hot but not extremely hot i can still handle to touch it. If it helps at all the subs are wired at 2ohms and the amp is 500watts rms @ 2ohms. I get very clean crisp hard bass im just worried about the amp getting too hott on a long trip. Thanks for any advice. following my locol atero shops advice the bass boost is set at 1/4, 80hrz and the gain is at 3/4
my name is Robert and im back after not building for 3+ years. hopefully some W.I.P pics coming soon.
Old 09-30-2010, 07:18 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: jl audio amp issues.
sounds like you need to put a fan on the amp, and you really should be concerned about an amp that gets really hot - you can damage it that way
Old 10-02-2010, 12:37 AM
Alright, i just installed a second amp today to run my interior speakers, everything seems to be in order, i banged it real hard for a good hour today and check how hot the jl amp was getting and it was cool to the touch, for my components i am running a jensen 300 watt that i had laying around the house and it stayed cool to the touch also. What type of fan do you recomend for the jl amp? i have several extra cpu fans around the house can i wire one of these to work??? thank you.
Old 10-02-2010, 09:38 AM
Audio Guy
were you runninmg your interior speakers off of the JL too ? A computer fan will be fine, install it to blow accross the top of the amp.
Old 10-02-2010, 05:58 PM
No i was not useing the jl amp to power interior speakers. i just invested in new speakers and hooked up the little jensen to power them so i could actually hear vocals clearly because my bass from the jl and mtx's is crazy,lol. i will install a cpu fan asap. can i hook it up to the remote turn on???? thank you.
Old 10-02-2010, 11:31 PM
Audio Guy
I wouldn't, I would use the remote turnon to power a relay - then use the output of the realay to turn on everything in the trunk
Old 10-14-2010, 06:09 PM
Audio Guy
yes, the remote will turn the relay on - it will only draw a few hundred milliamps .. the real power will come from the same wire that's powering the amps. Look up bosch relay, it will explain how it works.
Ga Audio Amp? nova_gh Grand AM 8 01-30-2005 12:57 PM
f/s 2 12" JL w3's with 1100 watt memphis audio amp acidbyte7 Celica 0 02-16-2004 11:24 AM
Lightning audio amp help psychochild2005 Car Audio 6 12-02-2003 11:34 PM
MA Audio Amps chucksnee Car Audio 1 04-17-2003 08:28 PM
Arc Audio amps pnut420 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 04-02-2003 11:27 PM
