Old 09-30-2010, 10:18 AM
mikeso_81 mikeso_81 is offline
Gravity Brake Bleeding
Hi,
I just replaced my rear calipers and I am about to bleed the brakes. I was reading somewhere that I can gravity bleed the brakes. From what I understand, is that you just open up the caliper and let the fluid drain? Is this better that the traditional two person pump up the brakes and release the bleeder method?
2001 Pontiac Grand Prix
3.8L GT
Thx
Old 09-30-2010, 10:51 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Gravity Brake Bleeding
Yes, that's pretty much it for gravity bleeding. Just take care to keep the master cyl full, and expect it to take a bit of time.
I slip a clear plastic hose over the nipple and direct the fluid into a container so it does not spill everywhere. It's easy to see when the bubbles stop coming out by using a clear plastic hose. Do the caliper with the longest brake line first, this is usually the passenger side rear.
I have always had good luck with the gravity bleed, but it depends on the results. If you do not get a firm pedal with a gravity bleed, try the traditional two-person method.
Old 09-30-2010, 11:27 AM
Excellent. When I gravity bleed the brakes, do I need to keep the plastic line that I attach to the bleeder above or below the bleeder valve?
Thx
Old 09-30-2010, 11:49 AM
inafogg inafogg is offline
below
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Bleeding brakes is supposed to be simple right? prosystem Engineering/ Technical 5 07-27-2010 08:10 AM
Bleeding 2001 F'in Brakes Nickboudro Silverado 8 02-08-2010 08:09 PM
2000 blazer / jimmy brake bleeding issue rmwilson Problem Diagnosis 11 12-16-2009 10:14 PM
98 bleeding brakes/ABS light comes on PHXAuto Intrigue 2 09-28-2009 08:51 AM
brake brakes bleed fluid anti-lock drdd Jimmy 2 06-20-2005 01:37 PM
