Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 06-19-2005, 09:18 PM
drdd's Avatar
drdd drdd is offline
brake brakes bleed fluid anti-lock
Hey All,
I don't have any braking problems but, the fluid in the master cylinder looks really dark. I'm not the original owner of my 97 4.3 W Jimmy (117,000 miles) but I bet the brake fluid has never been changed.
Is this worth the time and $$?? ... just as preventive maintenance? I do have 4WD and anti-lock brakes (4wheel i think). Does this complicate things?
I've done brake pads and bled brakes before but Ive never done it on a vehicle with anti-lock brakes.
Thoughts?
Thanks
Old 06-20-2005, 08:02 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: brake brakes bleed fluid anti-lock
Originally Posted by drdd
Hey All,
Thoughts?
Thanks
Well it's easy to just gravity bleed most of the system. Just keep opening bleeders with buckets under neath and keep pouring fresh fluid in. You won't get the ABS module flushed though without a tech 2 scanner to command the ABS valves to open up.
Old 06-20-2005, 01:37 PM
drdd's Avatar
Re: Re: brake brakes bleed fluid anti-lock
Thanks, that's what I thought ... I just wasn't sure with the ABS and all.
