Go Back   Automotive Forums Car Chat > Buick > Roadmaster
Old 09-28-2010, 07:57 AM
Art234 Art234 is offline
92 Roadmaster AC Problem- F/C flashing, No AC
My 92 Roadmaster (my daughter's actually believe it or not) just had the tranny replaced. When I picked it up, I noticed the climate control was set to 70, but the F (Fahrenheit) next to the temperature was blinking constantly and it was in Econ mode. As many times as I push the econ button, it stays in Econ, meaning no compressor.
I finally stopped, pushed again and it went off, but it didn't feel like the compressor came on. As soon as you start moving Econ comes back on.
Does anyone have an idea about that? What is the meaning of the flashing F ?
Thanks
Old 09-28-2010, 10:46 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 92 Roadmaster AC Problem- F/C flashing, No AC
I assume, if you have a flashing Fahrenheit display (light) you have auto climate control? If so, the flashing light indicates you have a fault in the system. The most common thing to cause a fault, would be low refrigerant level. Another problem is, the controller will loose memory of current settings if the battery is disconnected during mechanical service, without first turning the climate control OFF. Without voltage, the system controller will loose it's memory & calibration settings. Once the power is restored, the control unit will start in default (home) mode, searching & trying to recalibrate. It could take up to 50 ignition cycles to recover normal operation.
Old 09-28-2010, 03:41 PM
Thanks for the prompt reply. Yes it is a climate control model. I took it down to my friend's garage (they just put the new transmission in last week), and sure enough the coolant level is low, and the o rings at the compressor and condenser are leaking too.
Going to replace the rings, flush the system and refill with R134.
Next will be to fix the trip odometer--it sticks and affects the odometer as well...but I understand that's a known issue.
Thanks again for the guidance-you were right on the money.
1990 Accord - Tranny, speedo, battery problems winsett Accord/TSX/Accord Hybrid 2 12-03-2009 02:39 PM
More Problems with red flashing coolant light BrokeBeetle Beetle - New/New Beetle Convertible 2 09-19-2007 02:06 PM
1991 SI Starting problem, ecu light flash every second bucnoy '88 - '91 Civic | CRX | Wagon | Shuttlee 13 06-10-2005 07:58 PM
1992 Roadmaster problem Roadservant Roadmaster 5 04-19-2004 03:11 PM
Turn Signal Problem -- All Lights Flash At Once ghcdale Ninety Eight 3 03-08-2004 07:38 PM
