Old 06-10-2005, 04:10 AM
bucnoy bucnoy is offline
1991 SI Starting problem, ecu light flash every second
I was driving on the freeway one night and it just die. to make the story short...
I have no spark and the ecu light flash every second and won't stop. I don't know the code for this 1991 honda crx si. I have fuel coming in. The engine cranks ok. The fuses, Dist., cap, rotor look fine. Please help.
Old 06-10-2005, 06:51 AM
johnb16a2's Avatar
johnb16a2 johnb16a2 is offline
Re: 1991 SI Starting problem, ecu light flash every second
Hi Noob! Welcome!
So there are no pauses between flashes?
If there are no pauses maybe your ecu is the problem. Try borrowing one from a friend or get one from the junkyard (with a return policy) and drop it in to see if it fixes the problem. GL
Old 06-10-2005, 11:58 AM
Thanks for the welcome.
There are no pauses between flashes.
I'll try another ECU. Will a ECU on a 1991 Civic HB 1.5l work on a 1.6l crx?
Old 06-10-2005, 12:36 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
you sure its non stop blinking? i think the highest number of consecutive flashes is 20. check it again, there should be a little longer pause between codes.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 06-10-2005, 12:43 PM
Re: Re: 1991 SI Starting problem, ecu light flash every second
I'm positive. I turn key off and on 3-4 times just to make sure I wasn't dreaming. I count over 60 flashes with no pause then I got bored. It flash every second.
Old 06-10-2005, 12:55 PM
EF You's Avatar
EF Life Giver
wow
Old 06-10-2005, 01:24 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
that must be code infinity...means everything possible is wrong. Not really, that's interesting I thought dead ECU's just don't flash.
Old 06-10-2005, 01:47 PM
O.K. I use the 1991 Civic HB 1.5l ECU on the a 1.6l crx? The 1.5 ECU didn't start the CRX.
the 1.6 CRX ECU did start the HB 1.5 but it miss fire. So I'm thinking it not the ECU that is the problem. The ECU is working O.K. It just wasn't compatible.
So could it be the ignition coil?
Old 06-10-2005, 02:15 PM
you can't use the 1.5L ECU...it's the dual point injection, the 1.6 is multipoint...I'm confused.
Old 06-10-2005, 02:50 PM
right i guess i have to fine the 1.6l ecu just to make sure.
Old 06-10-2005, 03:20 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Re: 1991 SI Starting problem, ecu light flash every second
1.6L manual ECU "PM6" (auto won't work)
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 06-10-2005, 03:46 PM
LANDO10101 LANDO10101 is offline
Cool GROUND & SUPPLY
Trace Your Ecu Ground Clean It And Torque It Properly..
Find Your Ecu Main Supply Line At The Ecu Connection And Test It For A Continuos Power Supply..
Always Check The Obvious First...
Good Luck
Old 06-10-2005, 05:54 PM
Talking Re: 1991 SI Starting problem, ecu light flash every second.
Thanks everyone for your time. I found out what it was. I should have notice it when I first remove the dist. cap. The problem was the screw came loose from the rotor and has fallen out. It run fine now.
Old 06-10-2005, 06:58 PM
EF You's Avatar
EF Life Giver
happens a lot. a guy i did a b16 swap for called me once and said "the car just died, it wont start back up. you need to come here and fix it. im on the side of the road" i told him to pop the dizzy cap and check the rotor, and to be careful not to let the rotor screw fall out of the cap. he thought i was bullshitting and trying to get out of taking the ride.
well, 10 minutes later he called and said "you are a fucking honda god! how the hell did you know it was that?"
truth is, i didnt know for sure, i just knew there were a few quirky things about EFs that make them not start. and i told him to try that one first.
