Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-27-2010, 08:59 PM
ned032002's Avatar
ned032002 ned032002 is offline
RS having idle issues
My buddy has an RS and it's all of a sudden having an issue idling. He said he sometimes has to push the gas in order to keep it running but the odd problem is that when he pushes the clutch in, the car just dies. He has to really rev it up to keep going. Thoughts here?
Old 09-28-2010, 09:33 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: RS having idle issues
Almost sounds like bad compression. Compression test FTW! But I would check all vacuum lines first, and then test out the IAC to make sure that's working properly. Not sure with the clutch though.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-28-2010, 10:43 AM
ned032002's Avatar
I think the problems are unrelated. I think she wants to stall because of pressure on the crankshaft and there being such a low idle that she just wants to stall. I'm going to have him test the isc and clean the throttle body.
Old 09-28-2010, 10:58 AM
david-b's Avatar
Dave is THAT guy
IAC, not ISC... similar, but not the same
75 Monte Carlo
Old 09-28-2010, 11:28 AM
ned032002's Avatar
That's just how I roll
1992 E350 Idle Fluctuation in Park ?? calmike14 Econoline 1 09-27-2010 08:26 PM
1995 mustang gt gt40 crate swap on going idle issues dcevil79 Mustang Problem Diagnosis 1 09-16-2010 05:35 PM
2004 ram 1500 4.7 overdrive and idle issues mrwrench Ram Pickup | Ram SRT10 2 06-03-2010 10:22 AM
starting/ warm idle issues thunderbirdcoupe89 Thunderbird 2 12-24-2009 10:36 AM
help, speratic brake issues and throttle-off-idle issues. 94tegRS Camry/Camry Hybrid/Vista 3 11-08-2006 02:56 AM
