Old 09-27-2010, 02:47 PM
STEVEO4025 STEVEO4025 is offline
Fuel injector not working
I recently noticed the car idling a little rough, almost like a misfire. Changed plugs and wires, still had problems. Last week I ran half a can of sea foam through intake, helped for a little while (under 100 miles), now one of my injectors does not spray. Could it be that the use of sea foam knocked some dirt loose and its now clogged? Will another blast of seafoam help or what? Thanks guys for your help and time.
Old 09-27-2010, 07:55 PM
danielsatur danielsatur is offline
Re: Fuel injector not working
Do an ''out of car injector service''
A diesel shop will do a micro bath, blow out, and test the flow rates.
Old 09-27-2010, 09:25 PM
Davescort97 Davescort97 is offline
Escort guy
I'm not questioning your ability, but how do you know it's not spraying? Is it because you can't here it operating with a mechanics stethoscope? Check the resistance across the terminals of the injector. Resistance should be 11-18 ohms. Injectors a relatively expensive for their size. I would go along with danielsatur unless there is no diesel shop close to where you live. I'd just replace the injector. It may have been the problem all along.
Old 09-30-2010, 01:28 PM
I know the plugs and wires are working okay for a fact. The way I know the injector is not working is I went down the line, pulling the relay to each injector. The first three, upon pulling the relay almost drowned out the engine. Upon pulling the fourth one, there was no change in how the engine ran, so I know that it is the problem, just not sure what to do about it is all.
Old 09-30-2010, 02:14 PM
Roll the injector just like a bad plug or wire.
Consider getting a used one from a salvage yard.
Also check the compression on the missing cylinder, and compare with the other 3.
Fuel Injectors Not Working........ Honda1000 JDM Motor & Parts info/chat 2 07-30-2008 03:41 PM
fuel injectors not working f150hotrod Dakota 1 06-11-2005 04:20 PM
fuel injectors not working ACE1969 C/K 2 09-03-2004 05:32 PM
1991 S-10 4.3L Fuel Injectors not working krumrei S-10 8 06-12-2004 11:02 PM
Fuel Injector NOT working SEP Fiero 0 02-29-2004 10:04 PM
