Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-26-2010, 04:56 PM
ruberg ruberg is offline
2000 Chevy Impala ABS and Traction OFF Light
When i start my car and hold the brakes the ABS and Traction Off light will NOT come on, but when i let go of the brakes they both come on. The brakes work fine and the brake fluid is full. Any ideas on what could be triggering these lights
Old 09-27-2010, 07:44 PM
HeMi101's Avatar
HeMi101 HeMi101 is offline
Send a message via AIM to HeMi101 Send a message via MSN to HeMi101 Send a message via Yahoo to HeMi101 Send a message via Skype™ to HeMi101
Re: 2000 Chevy Impala ABS and Traction OFF Light
Could be as bad as a Problem with the EBCM, or more likely a Wheel Hub. Best bet would probably be to get the ABS Code read, would narrow down your problem.
Old 10-11-2010, 06:00 PM
waterkeeper03 waterkeeper03 is offline
Working it out
I had ABS and Traction lights showing on my 04 because my brakes needed to be changed. new pads and rotors and it stopped. had to squeeze the brakes down so far the level would show as low and the lights come on. there are apparently no chirpers on these cars so this is how they tell you to get your brakes done...
maybe just time for brakes. still could be a bigger issue tho
Old 10-12-2010, 09:31 AM
MallocArray MallocArray is offline
My 2004 Grand Am did the same thing a few months ago. Replaced both front wheel hubs and the lights went away.
Old 10-24-2010, 09:59 PM
Iflylow's Avatar
Iflylow Iflylow is offline
The ABS and Trac lights were telling you the BCM had shut off those two systems due to low brake fluid. The fluid level was low because the brake pads were almost worn out, causing the pistons to be extended farther in the calipers, and therefore requiring more fluid from the reservoir.
The pads do have tabs on them that squeal when they are worn enough.
ABS and Traction Control Lights on after Jump start jbinramona Seville 0 06-22-2010 10:11 AM
2002 GT ABS and Traction Off Lights mikeswaggs Grand Prix 7 01-09-2007 02:26 PM
ABS and traction off lights on together cdawg331 Grand Prix 3 11-28-2005 03:21 PM
ABS and Traction off light keep coming on brots06 Grand AM 1 06-19-2005 05:53 PM
ABS problems.....ABS and Traction off light came on at same time Jeff2392 Bonneville 4 06-10-2004 07:04 PM
