Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 05-20-2003, 02:25 AM
dryworks107 dryworks107 is offline
hey del, what you do to your guage?
hey del, when you tried to install your reverse indiglo, did you pull out your needle too? how did you messed up your guages??
Old 05-20-2003, 02:10 PM
del del is offline
móddə rąytər
nah, i just tried to slip it over the needle, like the instructions said. i got the speedometer one in fine, but not the tach. not sure exactly how the needle got fucked up, it just did.
and next time if you need to get a hold of someone directly, just PM that member. but i guess i'll let it slide this time.:silly2:
Old 05-23-2003, 04:20 AM
hey del, guess what? i installed my Reverse indiglo guage today.
took about hour and a half. with my friend jimmy (he did 95% of work though, lol)
anyhow, we removed the guages from the cluster by removing the screws in the back. (there is 12 of them) and then we cut out the original black face. then we slide the face over it. however, we did cut through the white face for it to be able to fit over the speedometer guage because the needle is so freaking huge....so anyhow, its done.
the only problem we have now is the wiring.
for some reason, its a mess.
we connect the wires to the illuminatiing wire, and the ground.
when we turn the parking lamp on, the indiglo goes on. and then when we continue and turn the headlamp on, the indiglo shuts off.
tested every freaking wire with the tester and there seems to be no problem...........dont know what is going on, so on saturday, we are going to try adding a relay to see if it will fix the problem.
if not, i will either wire it to my ignition or buy a freaking switch to switch on or off my reverse indiglo guages.
what you think?
Old 05-23-2003, 12:14 PM
umm......how do you pm someone? i am sorry, didnt mean to offend you. shoot............i will find out how to pm some one. sorry again.
Old 05-23-2003, 03:28 PM
del del is offline
móddə rąytər
there's a choice of links below the posts. one of them reads "Send PM". so whoever you want to PM, just click that. no offense taken. :sun:
and what power source are you using to connect?
Old 05-23-2003, 04:25 PM
toKenaZngUy040 toKenaZngUy040 is offline
Send a message via AIM to toKenaZngUy040 Send a message via Yahoo to toKenaZngUy040
hey man why don't you find some kinda light that turns on when you turn on your parking and headlights and use that power source like a ash tray light or something like that....that's what i did and it works fine...i even hooked up a switch to it so i can turn it off when i want....i don't have a 5th gen lude so i don't know if there's a light in the ash tray or not...but that's a start!
Old 05-23-2003, 11:45 PM
actually, i think there is a light in the ashtray.....
but anyhow,
what i dont get is
how come when you turn on the head light the indiglo goes off???????~!~~~~
Old 05-24-2003, 02:28 AM
what do you mean what power source ???
ok..hmm....lets see.....
on the left side of the steering wheel
there are three buttons. one is for lights (brighter/dimmer)
one is for power moon roof
and one is for cruise
behind the lights switch
there are three wires.
i think that is called the illumination wire or something
and one out of the three is the ground.
so the indiglo is wired on 2 out of the three wires ( i think....)
.............that is as far as i know so far.
find out more tomoorw
might hook it up to a seperate switch if the relay doesnt work. LOL
kinda gay though......a switch for indiglo guages......
Old 05-24-2003, 07:56 AM
i think that relay won't fix the problem. i would just find a different power source and try that. try hooking the power and the ground to the light in the ashtray and see if that works, then you can do whatever you want to it like a switch or whatever..
Old 05-29-2003, 03:20 AM
yes, the indiglo is finally good
the relay has worked.
My SH finally shines with blue reverse indiglo lights that matches all the other lights in mah car.
What temp does your guage normally read? a_alyte Grand Prix 10 02-20-2008 05:26 PM
OT: what was your first car, what car do you wish you still had? nineball481 Silverado 27 10-20-2005 05:35 PM
Hey Gothamist, Whats the scoop on your rear bumper? Sc00ter Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 6 08-28-2001 05:36 PM
