Old 09-24-2010, 12:53 PM
ws50599 ws50599 is offline
where is the turbine speed sensor
I have a 1992 Geo Metro automatic. and it does not shift, I have to manually shift it...I have changed the transmission module under the dash, the two shifting solenoids in the tranny and now I hear it may be the turbine speed sensor located on the tranny. Does anyone know where it is on the tranny? How about where do you get one?
Old 09-24-2010, 06:26 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: where is the turbine speed sensor
it is on top of the tranmission. held in with the 10mm bolt, has 2 wires going into one plug, its black. once you get it out its easy to test its just a coil of wire wrapped around a iron core. if it has continuity its good, if its open its bad
Old 09-25-2010, 04:45 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
I've never heard of such a thing. There is a vehicle speed sensor plugged into the top of the tranny that has already been described by Crvett69.
You can go on replacing things that you"heard it might be" until you have an entirely new car that won't shift, or you can buy a proper manual and troubleshoot the problem.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 09-25-2010, 11:27 PM
I can consider this 92 Geo Metro as a hobby...fun to work with...so messing around with things and trying to fix stuff is fun to me. I have a manual...it doesn't talk much about the tranny, nor does it mention speed sensors...
Old 09-26-2010, 04:15 AM
Woodie83's Avatar
That came across as unnecessarily mean of me, sorry. Here's a link to a troubleshooting guide, don't know how good it is, just the first thing I found: http://www.teamswift.net/viewtopic.php?f=9&t=35213 I think more reading about at TeamSwift will get you more info, your failure is not rare.
Seems to me, if it shifts fine manually, it has to be the controller, solenoids, or the wiring in between. Taking my advice on an automatic transmission is not the best way to go, I've only owned one in my entire life and that was 40 years ago.
Woodie
Old 09-26-2010, 05:12 AM
Crvett69's Avatar
i had one that would start out in second gear and sort of shift into 3rd halfway, was acting really weird. if i unplugged the transmission computer i could shift it manually. the speed sensor on top of the transmission was open, replaced it and now it shifts and drives fine. like i said, test yours with a ohm meter
Speed Sensor spgoethals Taurus | Taurus Wagon 3 04-06-2009 06:35 AM
Speed sensor maybe transmisson???? c_evans1979 Caravan | Voyager 8 03-15-2009 12:27 PM
location of the input turbine speed sensor jdavis1 Stratus 2 09-19-2005 11:42 PM
Turbine Speed Sensor zacuda Aurora 0 02-23-2005 10:57 PM
Input/Turbine Speed Sensor... LesGrandsPieds Aurora 1 01-03-2005 09:08 AM
