Old 09-23-2010, 03:55 PM
fromhere2there fromhere2there is offline
Vacuum line on MAP
Hello,
I have a 91, 3.1 Euro. On the MAP sensor is a vacuum line that goes to intake and on to fuel regulator. The other line is bigger and rubber, about 18 inches long. Where does this connect?
I can feel suction when I give the engine gas so it must need to be connected to something.
Any help, please.
Old 09-23-2010, 06:55 PM
maxwedge maxwedge is online now
A990 racer
Re: Vacuum line on MAP
Power br. booster, pcv valve?
Old 09-24-2010, 06:02 PM
I can't find anywhere on the power booster to plug in and PCV hose is attached already. This hose is about 18 inches long and the way it's positioned should connect to something on the drivers side.
Old 09-24-2010, 10:54 PM
Blue Bowtie's Avatar
Registered Offender
Purge valve?
Old 09-26-2010, 09:21 AM
Where is the purge valve? And what is it? I looked on auto zone web and got nothen.
I know this hose attached to something because it has a permanent bend in the rubber now from being hooked up for years.
Map Sensor Vacuum Line brooket E Series 2 12-05-2006 06:34 AM
89 F 150 VERY high idle, unplug vacuum to MAP sensor, all's well rosenbarn F Series 0 06-26-2006 09:29 AM
1998 2.4 map vacuum line missing jmarwoodjim Cavalier 1 06-17-2006 01:13 PM
Broken vacuum line from vacuum switch to vacuum ball 97BlazerDude Blazer 1 08-07-2005 02:53 PM
Vacuum line and schematics Elizabeth R F Series 1 12-20-2001 01:22 PM
