Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 09-22-2010, 07:23 PM
Zoltan137 Zoltan137 is offline
Skipping Third Gear
I have a problem with my recently rebuilt tranny.
If I drive aggressively it runs the gears fine, but if I drive like I normally do it almost seems to skip third gear and bog down into 4th. It had a code for the park/neutral switch but that went away when I replaced the TPS, MAF and Plenum with some junkyard parts and hasn't returned.
I just want some ideas on what I can do without spending too much more money. I was thinking one of the shift solenoids was sticking, but I am not sure how to check it.
Old 09-23-2010, 08:21 AM
maxwedge maxwedge is offline
A990 racer
Re: Skipping Third Gear
You need a scan with a trans function scanner to look at solenoid commands and gear ratio errors also make sure you have good vacuum to the modulator if so equipped. Always post the year also.
Old 09-23-2010, 11:12 AM
That's my fault, it's a '93.
I will give the modulator a look and get back to you. I am not sure if my mechanic friend has a trans scanner, but I will ask.
99 cougar no o/d, skips 2nd gear, transaxle light dallas6916 Cougar 15 02-19-2017 07:31 PM
1993 Camry transmission skips 2nd gear mclark999 Camry/Camry Hybrid/Vista 0 07-31-2010 01:56 PM
Transmission skipping 2nd gear redhors66 Jimmy 8 05-22-2006 03:59 PM
996 Auto Second to Third Gear Shift Hesitation OrtegaHwy 911 2 08-20-2003 05:49 PM
