Old 09-21-2010, 09:51 PM
BigbadBill4x4 BigbadBill4x4 is offline
Angry 94 1500 Trans shift problem
Howdy folks,I have a 94 1500 5.7l 4l60e.I have come to realize that the truck starts from a stop in 3rd gear.I bought the truck a few months ago and noticed right away that it seemed to take alot of gas to take off.I really didn't give this much thought because at the time I was more worried about the fact the overdrive didn't seem to work and the sluggish take off was more engine than trans.How I came to the conclusion that I am starting in 3rd is,I started watching my tach for an rpm change while accelerating and it doesn't change.If I manually shift L1-L2-D,there is no rpm change from L1 to L2,but there is an rpm drop from L2 to D.But I still think it starting in 3rd.I took it out on the highway 2 days ago to reconfirm whether OD is working or not and I got 3000 rpm's at 60 mph.Oh yeah,reverse works just fine.So,if anyone has any input on this,I would be thankful.If I missed any details,just let me know.Thank you all in advance.
Old 09-21-2010, 11:43 PM
transman618 transman618 is offline
Re: 94 1500 Trans shift problem
You need to have a trans shop put a scanner on it and check for trouble codes. Since this is not an OBDII vehicle you just cant take it to a local auto parts store for a free scan. You are either in limp mode because the computer has found a fault or you have lost power to the transmission which will result in 3rd gear starts. Let us know what they find.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
Old 09-22-2010, 09:17 PM
Hey thanks for the reply.I have had it hooked up to a scan tool because my check engine light comes on at times,no trans codes,though.Besides the obvious broken wires,what would be the vause of no power to transmission?I will check to see if I have power tomorrow.Is there a particular wire in the plug I should probe?Thanks for the help.
Old 09-23-2010, 12:10 AM
Yes, check the pink wire on the round connector on the passenger side of the transmission. With the ignition switch in the "ON" position you should have 12vdc
transman
Old 09-24-2010, 04:54 PM
Well I have to say I never get as lucky as I did today.Taking your advise,I went out to check the plug for power.I disconnected it first so I could do a visual inspection first.while moving the wires around to check them for fraying,melting,breaks,etc,one of them pilled out of its cavity.So I pushed it back in till I heard the click.I then checked all the others to make sure they were fully seated.I found a total of 5 wires not seated in their spots.Plugged it back in and went for a test drive.A properly operating transmission is a beautiful thing.I was told by the guy when I bought the truck that he had to replace the trans,.I guess this derelict or whatever dipshit that worked on it screwed with the plug,not sure why.Anyway,I used up all my luck today and the weekend hasn't even started yet.Thanks for the help.
Old 09-24-2010, 06:23 PM
BEAUTIFUL....... Glad it was something easy and you are on the road at minimal cost.
transman
96 Ram 1500 Tranny shifting problem kylegrand Ram Pickup | Ram SRT10 1 02-14-2009 02:46 AM
1998 Trans Am Auto Trans Shifting problem USM Engine and Transmission 0 02-05-2008 11:12 AM
86' Delta 88 Trans shifting problems CharmedOutlaw Eighty Eight 0 05-17-2004 12:12 AM
96 exp. sport-manual trans shifting problems crazyford Explorer | Explorer Sport Trac 1 04-16-2004 08:49 AM
Auto Trans shift problem on 96 Grand AM 3.1L scottsman Grand AM 4 08-25-2003 06:53 PM
